Home » Archived » Test and Performance Tools Platform (TPTP) » JMX Attribute logging or statistical agent controller...
JMX Attribute logging or statistical agent controller... [message #76162] Mon, 03 July 2006 21:51 Go to next message
Originally posted by: nwilhelmi.comcast.net
Hello - Ultimately I am trying to insturment Tomcat so we can characterize
the load on the server. At this point I am trying to get very high level
statistics, requests/min / thread count / number of sessions / etc. I would
like to log this at some interval point to save the data for later review.
Is there anyway to do this within TPTP? I installed the tech previews and
can see the JMX values, however I don't see anyway to log/view the data. I
would really like to have something like the perfmon stuff. Has someone run
accross an application that does this already, someone has to have solved
this problem already? Should I be looking at writing a statistical data
collector agent to run on the server and collect the JMX attributes there?
Any pointers, suggestions, tutiorials would be greatly appreciated!!!
TIA!!!
-Nate
Re: JMX Attribute logging or statistical agent controller... [message #76226 is a reply to message #76162] Tue, 04 July 2006 13:51 Go to previous message
Originally posted by: nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 00622B69852571A1_=
Content-Type: text/plain; charset="US-ASCII"
Consider using dynamic Probekit in TPTP 4.2, which allows you to do
dynamic instrumentation of your Java applications. See the Probing Java
application behavior with Probekit presentation here:
http://www.eclipse.org/tptp/home/documents/conferences/eclip seCon2006/index.html.
Download the Demos.zip file for examples and instructions. Also see the
following help content in TPTP: "Monitoring and profiling applications" ->
"Collecting runtime data with user-defined probes".
Hope this helps,
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Consider using dynamic Probekit in TPTP
4.2, which allows you to do dynamic instrumentation of your Java applications.
&nbsp;See the Probing Java application behavior with Probekit &nbsp;presentation
here: http://www.eclipse.org/tptp/home/documents/conferences/eclip seCon2006/index.html.
&nbsp;Download the Demos.zip file for examples and instructions. &nbsp;Also
see the following help content in TPTP: &quot;Monitoring and profiling
applications&quot; -&gt; &quot;Collecting runtime data with user-defined
probes&quot;.</font>
<br>
<br><font size=2 face="sans-serif">Hope this helps,</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 00622B69852571A1_=--
Previous Topic:Automated GUI Recording and Swing/AWT
Next Topic:Profiling application that requires JVM 1.3
Current Time: Mon Sep 01 03:37:09 EDT 2025
Powered by FUDForum. Page generated in 1.12805 seconds
