Home » Language IDEs » PHP Development Tools (PDT) » Watching get_included_files()
Watching get_included_files() [message #76134] |
Thu, 17 July 2008 03:49  |
Originally posted by: christian.wolf.sedo.de
Hello everybody,
I'm currently (remotely) debugging a bigger Typo3 module project. Due to
class redeclaration, I tried to monitor all included classes with PHP's
get_included_files(). Adding it to the watch list showed me the total items
(70) and the first array chunk (items 0 - 31), but the following two chunks
aren't displayed at all. The expanding crosses for the chunks 2 and 3 show
up when I start the debug session, but the expansion itself doesn't work.
However, when adding the line
$includedFiles = get_included_files();
to the PHP file, inspection works as expected. But that's not the proper way
of debugging, of course.
Does anybody experience the same problem and has a solution?
Christian
Eclipse 3.3.2, Debian 4.0, Apache 2.2.3, PHP 4.4.4, XDebug 2.0.2
Re: Watching get_included_files() [message #76150 is a reply to message #76134] |
Thu, 17 July 2008 05:52   |
I am guessing you are using xdebug ?
The problem you are describing is due to the way watch expressions work and the amount of data
xdebug returns as default.
As you know watches are expressions not variables so when you watch something like
get_include_files(), there is no variable defined to hold the results in PHP. xdebug by default
returns only the 1st 32 elements of the array which is why you can see this information in the
watch. However when you try to expand the next set of elements it needs a way to query the next set
of elements, and there is no way to do that as there is no variable in PHP which is holding the
results. It is also not possible to re-evaluate the expression and get it to pass the next set of
elements.
A solution would be to enhance PDT to allow you to specify the max children property of xdebug. This
would control the amount of information xdebug would send back when querying information about
arrays/objects such that if you set this value to say 100 it would transfer 100 elements back on
each request (and that show up as array chunks of [0-99] [100-199] etc, and in the watch expression
it would contain everything you need in the first chunk). The alternative is to do as you have done
by creating a variable to hold the information.
I have raised an enhancement https://bugs.eclipse.org/bugs/show_bug.cgi?id=241219 to record this and
if you are interested, please register your vote.
Dave Kelsey
Christian A. Wolf wrote:
> Hello everybody,
> Christian
Re: Watching get_included_files() [message #76166 is a reply to message #76150] |
Thu, 17 July 2008 08:18   |
Hello Dave,
you guessed right, sorry.
> and the amount of data xdebug returns as default.
> something like get_include_files(), there is no variable defined to hold
> the results in PHP. xdebug by default returns only the 1st 32 elements of
> the array which is why you can see this information in the watch. However
> the next set of elements, and there is no way to do that as there is no
> variable in PHP which is holding the results. It is also not possible to
> re-evaluate the expression and get it to pass the next set of elements.
Ok, I didn't know about the limitation of XDebug to the first 32 elements
when debugging remotely, thank you. I found no public documentation how to
raise this parameter's default value.
> children property of xdebug. This would control the amount of information
> xdebug would send back when querying information about arrays/objects such
> on each request (and that show up as array chunks of [0-99] [100-199] etc,
> and in the watch expression it would contain everything you need in the
> first chunk). The alternative is to do as you have done by creating a
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=241219 to record this and if
This is a very nice enhancement; I will vote for it when I found my Eclipse
Bugzilla login.
I'm curious, how would PDT raise that value? Would it send special commands
to XDebug, or would it repeat the default queries? Or don't you know that by
now?
Christian
Re: Watching get_included_files() [message #76213 is a reply to message #76182] |
Thu, 17 July 2008 11:54  |
Hello Dave,
> PDT can do it via the "feature set" command for the max_children
> feature, and this works. What is needed is a way for the user to set the
> value. This is likely to be a global preference set in the debugger
> specific preferences for xdebug.
ah, very interesting, thank you.
By the way: PDT is a great plugin. I'm currently establishing it in my
company as the main IDE, especially the comfortable debugging is a
strong argument. Thanks (of course to the whole team) for all your good
work!
Christian
Current Time: Fri Jul 25 22:00:34 EDT 2025
Powered by FUDForum. Page generated in 0.05750 seconds
