Home » Language IDEs » Java Development Tools (JDT) » Eclipse Profiler Plugin
Eclipse Profiler Plugin [message #76128] Tue, 15 July 2003 12:21 Go to next message
Originally posted by: bob.news.gmx.net
I got me the profiler from http://eclipsecolorer.sourceforge.net/ but I
can't seem to get it to work: After extracting the ZIP in the Eclipse
plugins directory the Perspective is recognized but cannot be opened -
apparently because a class is missing:
java.lang.ClassNotFoundException:
ru.nlmk.eclipse.plugins.profiler.ui.ProfilerPerspectiveFacto ry
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(Delegati
ngURLClassLoader.java:866)
at java.lang.ClassLoader.loadClass(ClassLoader.java:255)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtensi
on(PluginDescriptor.java:130)
on(PluginDescriptor.java:167)
org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExt
ension(ConfigurationElement.java:103)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:158)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.ja
va:155)
org.eclipse.ui.internal.registry.PerspectiveDescriptor.creat eFactory(Persp
ectiveDescriptor.java:98)
org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Pers pective.java:6
53)
org.eclipse.ui.internal.Perspective.createPresentation(Persp ective.java:27
8)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:177)
org.eclipse.ui.internal.WorkbenchPage.createPerspective(Work benchPage.java
:965)
org.eclipse.ui.internal.WorkbenchPage.busySetPerspective(Wor kbenchPage.jav
a:617)
at org.eclipse.ui.internal.WorkbenchPage.access$8(WorkbenchPage .java:609)
at org.eclipse.ui.internal.WorkbenchPage$12.run(WorkbenchPage.j ava:2705)
org.eclipse.ui.internal.WorkbenchPage.setPerspective(Workben chPage.java:27
03)
org.eclipse.ui.internal.ChangeToPerspectiveMenu.run(ChangeTo PerspectiveMen
u.java:58)
at org.eclipse.ui.actions.PerspectiveMenu.run(PerspectiveMenu.j ava:331)
org.eclipse.ui.actions.PerspectiveMenu.runOther(PerspectiveM enu.java:346)
org.eclipse.ui.actions.PerspectiveMenu$4.widgetSelected(Pers pectiveMenu.ja
va:118)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:840)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1838)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1545)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.j
ava:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:
39)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorIm
pl.java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Any ideas what went wrong? TIA!
robert
Re: Eclipse Profiler Plugin [message #76492 is a reply to message #76128] Tue, 15 July 2003 23:18 Go to previous messageGo to next message
Originally posted by: scheglov_ke.nlmk.ru
Robert Klemme <bob.news@gmx.net> wrote:
May be you have earlier messages in log, which tells, why
ProfilerPerspectiveFactory was not loaded, for example your Eclipse
does not have some plugins. Try to remove log file, start Eclipse and
send me log file via mail.
Check also, that you don't have any earlier version of profiler installed.
> at
> at
> at
> at
> at
> va:155)
> at
> at
> 53)
> at
> 8)
> at
> :965)
> at
> a:617)
> at
> 03)
> at
> u.java:58)
> at
> at
> va:118)
> at
> at
> ava:845)
> at
> 39)
> at
> pl.java:25)
> robert
SY, Konstantin.
Re: Eclipse Profiler Plugin [message #76588 is a reply to message #76128] Wed, 16 July 2003 04:16 Go to previous messageGo to next message
Originally posted by: arnout.standaert.n-o-s-p-a-m.cit.kuleuven.ac.be
> http://eclipsecolorer.sourceforge.net/ but I can't seem to get
> it to work: After extracting the ZIP in the Eclipse plugins
<snip>
It's just a hunch, but I guess you haven't got the full Eclipse SDK
installed. Try the following:
Go to the profiler's UI plugin directory
"ru.nlmk.eclipse.plugins.profiler.ui", and open up plugin.xml in a
plain text editor. In the <requires> section, comment out the
following lines:
<!--<import plugin="org.eclipse.pde.ui"/>-->
<!--<import plugin="org.eclipse.pde.core"/>-->
This made things work for my Eclipse installation.
This issue has already been brought up several times, an
alternative solution would be to include 'optional="true"' in the
import statement. I think Konstantin once said to incorporate this,
but maybe he didn't manage to do it yet...
Maybe a good opportunity to get this to his attention again :-)
Kind regards,
Wald
Re: Eclipse Profiler Plugin [message #76619 is a reply to message #76492] Wed, 16 July 2003 04:23 Go to previous messageGo to next message
Thanks for the quick response! I'll get back at you via email.
robert
"Konstantin Scheglov" <scheglov_ke@nlmk.ru> schrieb im Newsbeitrag
news:dJGauj0SDHA.3800@fairy.ao.nlmk...
installed.
I
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > va:155)
> > at
> > at
> > 53)
> > at
> > 8)
> > at
> > :965)
> > at
> > a:617)
> > at
> > at
> > at
> > at
> > 03)
> > at
> > u.java:58)
> > at
> > at
> > at
> > va:118)
> > at
> > at
> > at
> > ava:845)
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at
> > 39)
> > at
> > pl.java:25)
> > robert
> SY, Konstantin.
Re: Eclipse Profiler Plugin [message #76664 is a reply to message #76588] Wed, 16 July 2003 06:07 Go to previous messageGo to next message
Wald <arnout.standaert@n-o-s-p-a-m.cit.kuleuven.ac.be> wrote:
Yes, you are right, these imports are again not optional.
Problem is that we do some restructuring, and I forgot to move
plugin.xml.
> Kind regards,
> Wald
SY, Konstantin.
Re: Eclipse Profiler Plugin [message #77646 is a reply to message #76664] Fri, 18 July 2003 05:07 Go to previous message
Thanks to Konstantin's help I was able to track down the error to - the
unzipper. It extracted not all files to where they belong but created an
additional directory presumably for paths that it regarded too long.
Aarrgh!
Thanks again
robert
news:YvR0OI4SDHA.540@fairy.ao.nlmk...
> plugin.xml.
> > Kind regards,
> > Wald
> SY, Konstantin.
Previous Topic:Editor preferences summary
Next Topic:W2K pro upgrade to 2.1.1 problem
Current Time: Mon Sep 01 02:37:11 EDT 2025
Powered by FUDForum. Page generated in 0.06542 seconds
