VE Problems - "Creation of Element Failed" [message #76122] |
Tue, 04 January 2005 00:54  |
Originally posted by: cmarth.mac.com
Hello -
I just installed VE, and I am having trouble creating visual classes. My
configuration is as follows...
1. Mac OS 10.3.7.
2. Eclipse SDK 3.0.1
3. GEF 3.0.1
4. EMF 2.0.1
When I select New->Visual Class, then go ahead and fill out the wizard
then hit 'Finish' I get the following error :
"Creation of Element Failed - See Error Log for Details"
The Error Log will show either of the following error:
"SyntaxError: The type java.lang.Object cannot be resolved. It is
indirectly referenced from required .class files"
from the org.eclipse.ve.java.core plug-in followed immediately by an
internal error from org.eclipse.jdt.ui plug-in, which I assume results
directly from the first error. I'm not sure what is wrong - any
suggestions? Thanks in advance for any help.
Chris Marth
Re: VE Problems - "Creation of Element Failed" [message #76138 is a reply to message #76122] |
Tue, 04 January 2005 06:22  |
Originally posted by: myersj.nospam.gmail.com
Hi Chris,
The VE is not officially supported on OS X yet. Initial support has
been made, but you must run VE 1.0.2 on Eclipse SDK 3.1 M3 or later.
Good luck!
- Jeff
Chris M. wrote:
> Hello -
> 1. Mac OS 10.3.7.
> 3. GEF 3.0.1
> 4. EMF 2.0.1
> Chris Marth
Re: VE Problems - "Creation of Element Failed" [message #604251 is a reply to message #76122] |
Hi Chris,
Good luck!
- Jeff
Chris M. wrote:
> Hello -
> 1. Mac OS 10.3.7.
> 3. GEF 3.0.1
> 4. EMF 2.0.1
> Chris Marth
FUDForum. Page generated in 0.04676 seconds
