Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » New to JET can't access xsi:type value
New to JET can't access xsi:type value [message #76115] |
Wed, 21 March 2007 04:44  |
Originally posted by: evaandoli.dodo.com.au
I assume this will be a quick one for most of you
I have the following line in my XML file:
<rules xsi:type="com.ibridge.stepbystepmodel:DecisionNode" tag="WhichState">
and I want to access the type in my JET template.
I can access the 'tag' attribute using
<c:get select="$attrib/@tag" />
But I can't seem to get to the type, i have tried both:
<c:get select="$attrib/@type" />
and
<c:get select="$attrib/@xsi:type" />
Can anyone point me to the right syntax.
Thanks.
Re: New to JET can't access xsi:type value [message #76146 is a reply to message #76130] |
Wed, 21 March 2007 10:50   |
Stu:
Short answer: you can't. OK, you can't easily.
Explanation: JET is loading the XML file using EMF's XML/XMI
deserialization, and evaluating XPath expressions on the actual EObjects.
The xsi:type gets transformed into the EObject's eClass - unfortunately, the
eClass of an EObject is not an EFeature, and is thus invisible to the XPath
engine.
Work arounds:
It looks like the 'rules' feature declared type is an abstract type, and you
want to process the concrete sub-types differently. Here are a couple of
ways to do this:
a) If you just want to process DecisionNode elements, do the following. I'm
assuming $rulesContainer is a variable referring to the parent of the nodes
<c:iterate select="$rulesContainer/rules[self::DecisionNode]"
var="decisionNode">
</c:iterate>
the predicate [self::DecisionNode] filters the elements in the 'rules'
reference list to those whose eClass has the name 'DecisionNode'. If 'rules'
feature is a containment feature, and its containing EClass has no other
containment features that can contain DecisionNodes, then you could use the
expression $rulesContainer/DecisionNode
b) If you want to process all the rules, but do something different for each
type. Try:
<c:iterate select="$rulesContainer/rules" var="node">
<c:choose>
<c:when test="$node/self::DecisionNode">
... $node is a DecisionNode
</c:when>
<c:when test="$node/self::AnotherNode">
... $node is an AnotherNode
</c:when
</c:choose>
</c:iterate>
c) More time consuming, you could write an XPath function the returns the
eClass. Then you could do:
<c:get select="eclass($attr)"/>
To write an custom XPath function, you need to create a plug-in with a
org.eclipse.jet dependency, and an org.eclipse.jet.xpathFunctions extension.
Each function is implemented as a Java class implementing the interface
org.eclipse.jet.xpath.XPathFunction and the method Object evaluate(List
arguments). I have an example that I will be putting into the jet examples
plug-in when I have time. Let me know if you're interested in this route.
Paul
> Stu wrote:
>> tag="WhichState">
>> and
>> Thanks.
Re: New to JET can't access xsi:type value [message #76241 is a reply to message #76146] |
Thu, 22 March 2007 06:35  |
Now that is not the simple reply I expected :-)
I guess I could add a derived attribute to the ecore model which returns the
java class.
(let me know if you think that is a bad idea)
Stuart
"Paul Elder" <pelder@ca.ibm.com> wrote in message
news:etrgok$sdo$1@utils.eclipse.org...
> Stu:
> the eClass of an EObject is not an EFeature, and is thus invisible to the
> XPath engine.
> Work arounds:
> you want to process the concrete sub-types differently. Here are a couple
> of ways to do this:
> I'm assuming $rulesContainer is a variable referring to the parent of the
> nodes
> var="decisionNode">
> </c:iterate>
> 'rules' feature is a containment feature, and its containing EClass has no
> other containment features that can contain DecisionNodes, then you could
> use the expression $rulesContainer/DecisionNode
> each type. Try:
> <c:choose>
> </c:when>
> </c:when
> </c:choose>
> </c:iterate>
> extension. Each function is implemented as a Java class implementing the
> interface org.eclipse.jet.xpath.XPathFunction and the method Object
> evaluate(List arguments). I have an example that I will be putting into
> the jet examples plug-in when I have time. Let me know if you're
> Paul
>> Stu wrote:
>>> Hi,
>>> tag="WhichState">
>>> and
>>> Thanks.
Re: New to JET can't access xsi:type value [message #603759 is a reply to message #76115] |
Wed, 21 March 2007 09:10  |
Stu,
Please use the m2t newsgroup for JET2 questions. I've added it to the
"to" list, so you can continue to use this thread.
Stu wrote:
> and
> Thanks.
Re: New to JET can't access xsi:type value [message #603761 is a reply to message #76130] |
Stu:
engine.
Work arounds:
ways to do this:
var="decisionNode">
</c:iterate>
type. Try:
<c:choose>
</c:when>
</c:when
</c:choose>
</c:iterate>
Paul
> Stu wrote:
>> tag="WhichState">
>> and
>> Thanks.
Re: New to JET can't access xsi:type value [message #603793 is a reply to message #76146] |
java class.
Stuart
> Stu:
> XPath engine.
> Work arounds:
> of ways to do this:
> nodes
> var="decisionNode">
> </c:iterate>
> each type. Try:
> <c:choose>
> </c:when>
> </c:when
> </c:choose>
> </c:iterate>
> Paul
>> Stu wrote:
>>> Hi,
>>> tag="WhichState">
>>> and
>>> Thanks.
Current Time: Tue Jul 22 03:14:47 EDT 2025
Powered by FUDForum. Page generated in 0.10681 seconds
