Home » Modeling » GMF (Graphical Modeling Framework) » Changing visual attributes based on model attribute values?
Changing visual attributes based on model attribute values? [message #76095] Wed, 08 November 2006 19:29 Go to next message
How can one change visual attributes (e.g. a connection's line pattern
between solid and dashed or its color) depending on the value of a
boolean or enumeration attribute in the model? E.g. I would like to
automatically toggle a connection's line pattern between solid and
dashed depending on a boolean flag "optional".
Is there a "declarative" way (i.e. via .gmfgraph and .gmfmap file) or is
there no other way than modifying the generated diagram code?
Michael
Re: Changing visual attributes based on model attribute values? [message #77766 is a reply to message #76095] Wed, 15 November 2006 09:07 Go to previous message
Originally posted by: 5d5.mail.ru
There is no "declarative" way, sorry (((
Here is an outline:
1. When link edit part creates it's figure check model and set figure
style as needed.
2. Override handleNotificationEvent(...) method in link edit part and
detect boolean attribute update in model; set link figure style if needed.
> Michael
Previous Topic:EMF properties view, with EMF attributes
Next Topic:label showing as <...>
Current Time: Sun Aug 31 22:39:34 EDT 2025
Powered by FUDForum. Page generated in 0.03724 seconds
