Finding possible values for enumerations from XSD [message #76094] |
Thu, 30 October 2008 02:06  |
I found this package after searching the web for something to help me
solve my problem:
I have an XML file that a user must edit and an XSD against which to
validate the resulting XML file.
I need to retrieve all the possible values for a field in this XML file
from a XSD file (to populate a dropdown with possible values for the end
user).
Can I use the functionality of this package to write something like that?
Or am I barking up the totally wrong tree here?
Any pointers would be much appreciated.
Etienne
Re: Finding possible values for enumerations from XSD [message #76142 is a reply to message #76127] |
Thu, 30 October 2008 11:58  |
Etienne,
Comments below.
Etienne wrote:
> Thanks for the prompt reply.
> I will work through the tutorial and see how I can apply that to my code.
> By the way, the code I am writing will be exposed as a service to be
> used by a front end that is not even written in Java.
> My service must take the XSD and XML tag path as inputs and then
> return all the valid values for that tag as output.
So you'll write your service in Java, but it will be used by some other
service that's not written in Java. You'll just exchange XML.
> So, even though I'll be looking at the Eclipse editor functionality
> this project gives me (for myself), my code will not be used in an
> Eclipse environment.
EMF works standalone just on the Java classpath. So does the generated
model. And the XSD model too...
> I'm currently using the built-in Java XSD validation functionality,
> but will definately be looking at this project's functionality for XML
> validation against an XSD as it may give me less criptic feedback in
> the case of failing validation than the standard Java libraries.
The XSD model is mostly focused on validating XSD instances, not so
much on validating XML documents whether they conform to the XSD.
> Thanks
> Etienne
Re: Finding possible values for enumerations from XSD [message #603396 is a reply to message #76094] |
Thu, 30 October 2008 06:50  |
--------------010608060201010304090100
Etienne,
Try this tutorial:
Tutorial: Generating an EMF Model using XML Schema
< http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html>
The Web Tools project also as an XML editor that will validate the XML
against the XSD...
> solve my problem:
> file from a XSD file (to populate a dropdown with possible values for
> the end user).
> that? Or am I barking up the totally wrong tree here?
> Etienne
<html>
<head>
http-equiv="Content-Type">
</head>
Etienne,<br>
<br>
Try this tutorial:<br>
<blockquote><a
href=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html">Tutorial:
Generating an EMF Model using XML Schema</a><br>
</blockquote>
against the XSD...<br>
<br>
<br>
Etienne wrote:
<blockquote
cite="mid:7e99eee69ea3033a3802f4695618a978$1@www.eclipse.org"
type="cite">I found this package after searching the web for something
to help me solve my problem:
<br>
<br>
Re: Finding possible values for enumerations from XSD [message #603400 is a reply to message #76113] |
Thu, 30 October 2008 09:46  |
By the way, the code I am writing will be exposed as a service to be used
My service must take the XSD and XML tag path as inputs and then return
So, even though I'll be looking at the Eclipse editor functionality this
project gives me (for myself), my code will not be used in an Eclipse
environment.
I'm currently using the built-in Java XSD validation functionality, but
validation against an XSD as it may give me less criptic feedback in the
Etienne
Re: Finding possible values for enumerations from XSD [message #603407 is a reply to message #76127] |
Etienne,
Comments below.
> Thanks
> Etienne
FUDForum. Page generated in 0.05328 seconds
