[Resolved] EMF / Teneo / Hibernate: Can not reload a EMap [message #716847] |
Thu, 18 August 2011 15:16 |
Bernard Sarter Messages: 88 Registered: August 2011 Location: Paris, France |
Member |
Following some tutorials (I'm a newbie in this area), I succeeded to save a EMF model that contains EMaps with teneo / hibernate in a mySql DB:
The 'save' seems to work only if I set the option EMAP_AS_TRUE_MAP to 'false'.
final Properties props = new Properties();
props.setProperty(Environment.DRIVER, "com.mysql.jdbc.Driver");
props.setProperty(Environment.USER, "root");
props.setProperty(Environment.URL, "jdbc:mysql://127.0.0.1:3306/" + dbName);
props.setProperty(Environment.HBM2DDL_AUTO, "create");
props.setProperty(PersistenceOptions.CASCADE_POLICY_ON_CONTAINMENT, "ALL");
props.setProperty(PersistenceOptions.CASCADE_POLICY_ON_NON_CONTAINMENT, "MERGE,PERSIST,REFRESH");
props.setProperty(PersistenceOptions.EMAP_AS_TRUE_MAP, "false");
HbDataStore dataStore = HbHelper.INSTANCE.createRegisterDataStore(dataStoreName);
dataStore.setEPackages(new EPackage[] { SysmodPackage.eINSTANCE });
dataStore.setDataStoreProperties(props);
dataStore.initialize();
SessionFactory sessionFactory = dataStore.getSessionFactory();
Session session = sessionFactory.openSession();
session.beginTransaction();
Long l = (Long) session.save(model);
but I don't know how to reload this model from the database.
I tried a
model = (Model) session.load("Model", l);
but it fails with the following error when it reaches my first map (myMap)
org.eclipse.emf.teneo.hibernate.HbMapperException: The field myMap can not be set using object org.hibernate.collection.PersistentList on target xxx.sysmod.impl.ModelImpl
at org.eclipse.emf.teneo.hibernate.mapping.property.EListPropertyHandler.set(EListPropertyHandler.java:457)
at org.hibernate.tuple.entity.AbstractEntityTuplizer.setPropertyValues(AbstractEntityTuplizer.java:583)
at org.hibernate.persister.entity.AbstractEntityPersister.setPropertyValues(AbstractEntityPersister.java:3822)
at org.hibernate.engine.TwoPhaseLoad.initializeEntity(TwoPhaseLoad.java:152)
at org.hibernate.loader.Loader.initializeEntitiesAndCollections(Loader.java:982)
at org.hibernate.loader.Loader.doQuery(Loader.java:857)
at org.hibernate.loader.Loader.doQueryAndInitializeNonLazyCollections(Loader.java:274)
at org.hibernate.loader.Loader.loadEntity(Loader.java:2037)
at org.hibernate.loader.entity.AbstractEntityLoader.load(AbstractEntityLoader.java:86)
at org.hibernate.loader.entity.AbstractEntityLoader.load(AbstractEntityLoader.java:76)
at org.hibernate.persister.entity.AbstractEntityPersister.load(AbstractEntityPersister.java:3268)
at org.hibernate.event.def.DefaultLoadEventListener.loadFromDatasource(DefaultLoadEventListener.java:496)
at org.hibernate.event.def.DefaultLoadEventListener.doLoad(DefaultLoadEventListener.java:477)
at org.hibernate.event.def.DefaultLoadEventListener.load(DefaultLoadEventListener.java:227)
at org.hibernate.event.def.DefaultLoadEventListener.proxyOrLoad(DefaultLoadEventListener.java:269)
at org.hibernate.event.def.DefaultLoadEventListener.onLoad(DefaultLoadEventListener.java:152)
at org.hibernate.impl.SessionImpl.fireLoad(SessionImpl.java:1090)
at org.hibernate.impl.SessionImpl.internalLoad(SessionImpl.java:1038)
at org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContainerUserType.nullSafeGet(EContainerUserType.java:384)
at org.hibernate.type.AbstractType.hydrate(AbstractType.java:104)
at org.hibernate.persister.entity.AbstractEntityPersister.hydrate(AbstractEntityPersister.java:2265)
at org.hibernate.loader.Loader.loadFromResultSet(Loader.java:1527)
at org.hibernate.loader.Loader.instanceNotYetLoaded(Loader.java:1455)
at org.hibernate.loader.Loader.getRow(Loader.java:1355)
at org.hibernate.loader.Loader.getRowFromResultSet(Loader.java:611)
at org.hibernate.loader.Loader.doQuery(Loader.java:829)
at org.hibernate.impl.SessionImpl.load(SessionImpl.java:985)
Any idea how to reload a model that contains maps and that was saved with EMAP_AS_TRUE_MAP=false ?
Thanks in advance for your support,
Bernard.
[Updated on: Fri, 19 August 2011 14:10] Report message to a moderator
Re: EMF / Teneo / Hibernate: Can not reload a EMap [message #716917 is a reply to message #716847] |
Thu, 18 August 2011 18:54 |
Martin Taal Messages: 5468 Registered: July 2009 |
I wonder, is this the complete stacktrace? There should be an underlying exception which is there also.
You can also debug into the EListPropertyHandler, put a breakpoint at line 457 to see what exception gets thrown.
Also what happens if you set EMAP_AS_TRUE_MAP to true?
gr. Martin
On 08/18/2011 05:16 PM, Bernard SARTER wrote:
> Hello,
> I tried a
> Best regards,
> Bernard.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: EMF / Teneo / Hibernate: Can not reload a EMap [message #717092 is a reply to message #717038] |
Fri, 19 August 2011 09:17 |
Hi Bernard,
It seems that Teneo does not detect that your field is an EMap field. Can you post your ecore model? If it is
confidential then you can also email it directly to me.
gr. Martin
On 08/19/2011 08:48 AM, Bernard SARTER wrote:
> Hello Martin, and thank your for your support.
> To answer to your questions / remarks:
> 1) Problem with the load: There was indeed a second part of the stack trace that I forgot to post, and here is it:
> Caused by: java.lang.IllegalArgumentException: Can not set org.eclipse.emf.common.util.EMap field
> xxx.sysmod.impl.ModelImpl.myMap to org.eclipse.emf.teneo.hibernate.mapping.elist.HibernatePersistableEList
> at sun.reflect.UnsafeFieldAccessorImpl.throwSetIllegalArgumentException(Unknown Source)
> at sun.reflect.UnsafeObjectFieldAccessorImpl.set(Unknown Source)
> at java.lang.reflect.Field.set(Unknown Source)
> at org.eclipse.emf.teneo.hibernate.mapping.property.EListPropertyHandler.set(EListPropertyHandler.java:445)
> ... 124 more
> 2) If I do not force EMAP_AS_TRUE_MAP to false, then even the session.save(model) fails with following errors:
> java.lang.ClassCastException: org.eclipse.emf.common.util.BasicEMap$DelegatingMap cannot be cast to java.util.Collection
> at org.hibernate.type.CollectionType.getElementsIterator(CollectionType.java:237)
> at org.hibernate.type.CollectionType.getElementsIterator(CollectionType.java:226)
> at org.hibernate.engine.CascadingAction.getLoadedElementsIterator(CascadingAction.java:459)
> at org.hibernate.engine.CascadingAction$5.getCascadableChildrenIterator(CascadingAction.java:256)
> at org.hibernate.engine.Cascade.cascadeCollectionElements(Cascade.java:423)
> at org.hibernate.engine.Cascade.cascadeCollection(Cascade.java:362)
> at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java:338)
> at org.hibernate.engine.Cascade.cascadeProperty(Cascade.java:204)
> at org.hibernate.engine.Cascade.cascade(Cascade.java:161)
> at org.hibernate.event.def.AbstractSaveEventListener.cascadeAfterSave(AbstractSaveEventListener.java:475)
> at org.hibernate.event.def.AbstractSaveEventListener.performSaveOrReplicate(AbstractSaveEventListener.java:353)
> at org.hibernate.event.def.AbstractSaveEventListener.performSave(AbstractSaveEventListener.java:203)
> at org.hibernate.event.def.AbstractSaveEventListener.saveWithGeneratedId(AbstractSaveEventListener.java:129)
> at
> org.hibernate.event.def.DefaultSaveOrUpdateEventListener.saveWithGeneratedOrRequestedId(DefaultSaveOrUpdateEventListener.java:210)
> at org.hibernate.event.def.DefaultSaveEventListener.saveWithGeneratedOrRequestedId(DefaultSaveEventListener.java:56)
> at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.entityIsTransient(DefaultSaveOrUpdateEventListener.java:195)
> at org.hibernate.event.def.DefaultSaveEventListener.performSaveOrUpdate(DefaultSaveEventListener.java:50)
> at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.onSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:93)
> at org.hibernate.impl.SessionImpl.fireSave(SessionImpl.java:713)
> at org.hibernate.impl.SessionImpl.save(SessionImpl.java:701)
> at org.hibernate.impl.SessionImpl.save(SessionImpl.java:697)
> Some info. about my config, just in case:
> - Eclipse 3.7
> - Teneo 1.2.0.v201107080556
> - Hibernate 3.6.0.201107071603
> Hope that helps ...
> Bernard.
The Netherlands
FUDForum. Page generated in 0.03078 seconds
