Home » Archived » Visual Editor (VE) » VE doesn't work
VE doesn't work [message #75955] |
Sat, 01 January 2005 22:33  |
Originally posted by: e.dominguez.ticino.com
Hi all, I have a problem.
I normally work with wsad.
Now I'd like to install eclipse 3.01 and configure some plugins and adds
to start developing application for study purpose.
I have installed eclipse, I have done an update and installed:
- EMF
- GEF
- VE
Now for the VE I have a problem.
I right click on my package, and chose new - visual class.
I give the class a name, from style chose Swing - Frame, so my superclass
is set to javax.swing.JFrame. I ask to generate a main method.
I click ok, the code is generated but nothing is displayed. I see the
white bg panel but no frame...
Tests:
After adding a button, the button is displayed on the VE, but the frame
not. If I add a JFrame from the palette then the VE displays the new
JButton, the new JFrame and... what's that... the JFrame that sould come
as first..
Tried to create a SWT class and the VE works fine.
Someone have a solution?
I have jdk 1.5 installed and using as default VM on my machine.
Best regards, sorry for my bad english
e.dominguez
Re: VE doesn't work [message #75974 is a reply to message #75955] |
Sun, 02 January 2005 06:22   |
Sorry, I post my .log file content too. There's an error... ;-)
!SESSION Jan 02, 2005 12:20:49.672
eclipse.buildId=M200409161125
java.version=1.5.0
!ENTRY org.eclipse.ve.java.core 4 0 Jan 02, 2005 12:20:49.672
!MESSAGE Exception thrown.
!STACK 0
java.lang.ClassCastException: org.eclipse.emf.java.util.JavaResourceImpl
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.createJavaInstances(JavaSourceTranslator.java:705)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.buildCompositionModel(JavaSourceTranslator.java:774)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:881)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:656)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1444)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
> I normally work with wsad. Now I'd like to install eclipse 3.01 and
> configure some plugins and adds to start developing application for
> study purpose.
> - EMF
> - GEF
> - VE
> superclass is set to javax.swing.JFrame. I ask to generate a main method.
> Tests:
> as first..
> e.dominguez
Re: VE doesn't work [message #75992 is a reply to message #75974] |
Sun, 02 January 2005 23:48   |
Originally posted by: MikeWainer.yahoo.com
Take a look at the postings in the "Where is the jContentPane?"
thread. You may be having the same problem. When I updated
to VE 1.0.2 it seemed to fix it.
> java.version=1.5.0
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
> at
> at
> at
> at
>> study purpose.
>> - EMF
>> - GEF
>> - VE
>> Tests:
>> as first..
>> e.dominguez
Re: VE doesn't work --> problem solved! [message #76008 is a reply to message #75992] |
Mon, 03 January 2005 05:43  |
Problem solved.
Installed version 1.0.2 and the problem has disappeared!
Thank you all!
Bye bye e. dominguez
>> java.version=1.5.0
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
> org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart..java:1444)
>>> study purpose.
>>> - EMF
>>> - GEF
>>> - VE
>>> method.
>>> Tests:
>>> frame not. If I add a JFrame from the palette then the VE displays
>>> the new JButton, the new JFrame and... what's that... the JFrame that
>>> sould come as first..
>>> e.dominguez
Re: VE doesn't work [message #604187 is a reply to message #75955] |
java.version=1.5.0
!STACK 0
> study purpose.
> - EMF
> - GEF
> - VE
> Tests:
> as first..
> e.dominguez
Re: VE doesn't work [message #604197 is a reply to message #75974] |
> java.version=1.5.0
> !STACK 0
> at
> at
> at
> at
> at
>> study purpose.
>> - EMF
>> - GEF
>> - VE
>> Tests:
>> as first..
>> e.dominguez
Re: VE doesn't work --> problem solved! [message #604202 is a reply to message #75992] |
Problem solved.
Thank you all!
>> java.version=1.5.0
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>>> study purpose.
>>> - EMF
>>> - GEF
>>> - VE
>>> method.
>>> Tests:
>>> e.dominguez
Current Time: Mon Sep 01 00:33:43 EDT 2025
Powered by FUDForum. Page generated in 0.05748 seconds
