Home » Modeling » GMF (Graphical Modeling Framework) » Defining audits in GMF
Defining audits in GMF [message #75934] Wed, 08 November 2006 12:41 Go to next message
Originally posted by: christian.daenekas.informatik.uni-oldenburg.de
I just again got stuck while enriching my editors functionality. I want
to define some audits using Java. So I defined an Audit Container, an
Audit rule, a Domain Element Target (i set this to an EClass named
operator that is represented by a Node in the editor). After that I
generated the gmfgen model and set the properties as described in the
mindmap tutorial
( http://wiki.eclipse.org/index.php/GMF_Tutorial_Part_2#Valida tion). This
means the 'Validation Enabled' property of the Gen Diagram element is
set to 'true', as is the 'Validation Decorators' property and the
'Validation Provider Priority' I have set to medium. All properties i
didn´t mention above have their initial values. In the generated code I
simple added "return false" so that every Node of the operator type
should produce an error. But when i use the editor i made nothing
happens validationwise. Any ideas?
Greetings,
Christian
P.S.: This is the implementation in the ValidationProvider class. Just
for your interest.
* @generated NOT
static class JavaAudits {
* @generated NOT
private static Boolean classSetConstraint(operator self) {
return false;
Re: Defining audits in GMF [message #75998 is a reply to message #75934] Wed, 08 November 2006 15:15 Go to previous messageGo to next message
Christian,
I just happened to be going through the MindMap Tutorial section that
discussed Audits. I had a similar problem because of some sort of error
in the constraint I defined. I was able to see the error in the
Preferences > Model Validation > Constraints section.
- Cherie
Christian Dänekas wrote:
> Hello,
> mindmap tutorial
> Greetings,
> Christian
> for your interest.
> * @generated NOT
> * @generated NOT
> return false;
Re: Defining audits in GMF [message #76163 is a reply to message #75998] Thu, 09 November 2006 05:18 Go to previous messageGo to next message
found something weird. I forgot to tell you that I set the validation
mode to live validation. This doesn´t seem to work. When I manually
exexute validation my "live mode" constraint is executed. Is this some
kind of bug or did I possibly forget something?
Greetings,
Christian
Cherie Revells wrote:
> Christian,
> - Cherie
Re: Defining audits in GMF [message #76179 is a reply to message #76163] Thu, 09 November 2006 06:27 Go to previous messageGo to next message
Hi Christian,
Including LIVE constraints in BATCH mode (on demand) validation is done by
desing here.
This could eventually detect violations introduced by external
modifications, as inside the editor,
it's guarded LIVE live validation.
However, they should allways be involved in model modifications in the GMF
editor.
/Radek
"Christian D
Re: Defining audits in GMF [message #76195 is a reply to message #76179] Thu, 09 November 2006 06:57 Go to previous messageGo to next message
Hi Radek,
I don´t know if I fully understand you there, but the problem I tried to
describe ;) is that constraints are not checked while i change things in
a Diagram, although I defined them to be used in live mode. So I guessed
there must be something wrong with the audits I defined. But since they
are correctly processed when I use Diagram>Validate I guess the audits
and constraints are correctly defined. But maybe I have to specify other
things in order to get the "live mode" to work. Any idea what could be
missing?
Greetings,
Christian
Radek Dvorak wrote:
> Hi Christian,
> desing here.
> editor.
> /Radek
Re: Defining audits in GMF [message #76211 is a reply to message #76195] Thu, 09 November 2006 09:07 Go to previous messageGo to next message
Christian,
It's sufficient to set the 'Live' mode for your constraint and it should be
checked on model changes in the editor.
Perhaps, what might be confusing for you is that the current GMF validation
implementation does not support
updating problem markers that resulted from on demand validation.
Could you please check whether your java constraint method gets called at
all?
I have just successfully passed such a usecase.
/Radek
"Christian D
Re: Defining audits in GMF [message #78728 is a reply to message #76211] Sat, 18 November 2006 22:42 Go to previous messageGo to next message
Originally posted by: atoulme.intalio.com
Hi Radek,
you mean that when the live validation is not decorating the faulty shapes ?
Is this a bug or a missing feature and will it be adressed ?
Is there a bugzilla bug for this ? Is it scheduled for 2.0 ?
Radek Dvorak wrote:
> Christian,
> all?
> /Radek
> "Christian Dänekas" <christian.daenekas@informatik.uni-oldenburg.de> wrote
> in message news:eiv54a$i6$1@utils.eclipse.org...
>> Hi Radek,
>> describe ;) is that constraints are not checked while i change things in a
>> are correctly processed when I use Diagram>Validate I guess the audits and
>> missing?
>> Greetings,
>> Christian
>> Radek Dvorak wrote:
>>> Hi Christian,
>>> by desing here.
>>> GMF editor.
>>> Regards,
>>> /Radek
Re: Defining audits in GMF [message #78889 is a reply to message #78728] Mon, 20 November 2006 10:20 Go to previous messageGo to next message
Hi Christian,
Yes, 'the live validation is not decorating the faulty shapes'.
In principal, there should not be a need to decorate shapes found invalid
during 'Live' validation.
The purpose of the live validation is to prevent model elements from
getting into an invalid state, so there
should be no elements to mark as faulty.
Of course, this is true only for 'Live' constraints with severity ERROR or
higher, as the modifying transaction
is rolled-back only if (validationStatus.getSeverity() >= IStatus.ERROR).
This logic is imposed by the transaction framework.
So for instance, 'Live' warnings produced by validation would not appear
as decorations,
though you might expect this.
On the other hand, having a 'Live' warning for a transaction outcome is
something
I find a bit strange from the constraint perspective, as the causing
modification gets
commited anyway and this can be captured by the 'Batch' validation easily.
So in my opinion, it is a good batch mode candidate.
The design does not address these rather rare cases as it can be handled
by on demand execution
of batch validation, which as I have said, includes also live constraints.
Or do you see another problem that I have not perceived?
/Radek
On Sun, 19 Nov 2006 04:42:21 +0100, Antoine Toulmé <atoulme@intalio.com>
wrote:
> Hi Radek,
> shapes ?
> Radek Dvorak wrote:
>> Christian,
>> should be checked on model changes in the editor.
>> validation implementation does not support
>> at all?
>> /Radek
>> wrote in message news:eiv54a$i6$1@utils.eclipse.org...
>>> Hi Radek,
>>> to describe ;) is that constraints are not checked while i change
>>> things in a Diagram, although I defined them to be used in live mode.
>>> So I guessed there must be something wrong with the audits I defined.
>>> But since they are correctly processed when I use Diagram>Validate I
>>> guess the audits and constraints are correctly defined. But maybe I
>>> have to specify other things in order to get the "live mode" to work.
>>> Any idea what could be missing?
>>> Greetings,
>>> Christian
>>> Radek Dvorak wrote:
>>>> Hi ,
>>>> done by desing here.
>>>> the GMF editor.
>>>> Regards,
>>>> /Radek
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Defining audits in GMF [message #78910 is a reply to message #78889] Mon, 20 November 2006 12:11 Go to previous messageGo to next message
Radek,
yes, you replied perfectly,
I am not so troubled by the fact that live validation isn't decorating
the shapes.
My problem is that we would expect an error message when a live
validation constraint is not respected, as it would be less frustrating
for the user. At least he would understand what he has done wrong.
Antoine aka Christian :)
Radek Dvorak wrote:
> Hi Christian,
> invalid during 'Live' validation.
> or higher, as the modifying transaction
> as decorations,
> something
> modification gets
> /Radek
> wrote:
>> Hi Radek,
>> shapes ?
>> Radek Dvorak wrote:
>>> Christian,
>>> called at all?
>>> /Radek
>>> "Christian Dänekas"
>>> <christian.daenekas@informatik.uni-oldenburg.de> wrote in message
>>>> Hi Radek,
>>>> tried to describe ;) is that constraints are not checked while i
>>>> change things in a Diagram, although I defined them to be used in
>>>> live mode. So I guessed there must be something wrong with the
>>>> audits I defined. But since they are correctly processed when I use
>>>> Diagram>Validate I guess the audits and constraints are correctly
>>>> defined. But maybe I have to specify other things in order to get
>>>> the "live mode" to work. Any idea what could be missing?
>>>> Greetings,
>>>> Christian
>>>> Radek Dvorak wrote:
>>>>> Hi ,
>>>>> the GMF editor.
>>>>> Regards,
>>>>> /Radek
> --Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Defining audits in GMF [message #78947 is a reply to message #78910] Mon, 20 November 2006 16:03 Go to previous messageGo to next message
Hi Antoine,
Sorry for the name mismatch :)
Please, try the following:
1) put the following fragment into the plugin.xml of your GMF editor and
provide your own context ID
<extension id="org.eclipse.gmf.ecore.editor.UIDefaultCtx"
point="org.eclipse.emf.validation.ui.UIRegisteredClientContext ">
<!-- use the client context ID from your GMF diagram editor -->
<clientContext id="org.eclipse.gmf.ecore.editor.DefaultCtx"/>
</extension>
2) add 'org.eclipse.emf.validation.ui' plugin dependency
3) choose 'Preferences/Model Validation/Show live validation errors in'
I will add support for this into the GMF editor generation procedure.
/Radek
"Antoine Toulm
Re: Defining audits in GMF [message #78967 is a reply to message #78947] Mon, 20 November 2006 17:10 Go to previous messageGo to next message
Thanks, I'll give it a try just now :).
Radek Dvorak wrote:
> Hi Antoine,
> </extension>
> /Radek
> "Antoine Toulmé" <atoulme@intalio.com> wrote in message
> news:ejsnil$8j8$1@utils.eclipse.org...
>> Radek,
>> I am not so troubled by the fact that live validation isn't decorating the
>> shapes.
>> My problem is that we would expect an error message when a live validation
>> constraint is not respected, as it would be less frustrating for the user.
>> Radek Dvorak wrote:
>>> Hi Christian,
>>> as decorations,
>>> something
>>> modification gets
>>> easily.
>>> constraints.
>>> Regards,
>>> /Radek
>>> wrote:
>>>> Hi Radek,
>>>> shapes ?
>>>> Radek Dvorak wrote:
>>>>> Christian,
>>>>> at all?
>>>>> /Radek
>>>>>> Hi Radek,
>>>>>> Greetings,
>>>>>> Christian
>>>>>> Radek Dvorak wrote:
>>>>>>> Hi ,
>>>>>>> the GMF editor.
>>>>>>> Regards,
>>>>>>> /Radek
Re: Defining audits in GMF [message #78971 is a reply to message #78967] Mon, 20 November 2006 18:49 Go to previous message
ok now I have some feedback on live validations.
Thanks!
Antoine
> Radek Dvorak wrote:
>> Hi Antoine,
>> and provide your own context ID
>> </extension>
>> /Radek
>>> Radek,
>>> decorating the shapes.
>>> frustrating for the user. At least he would understand what he has
>>> done wrong.
>>> Radek Dvorak wrote:
>>>> Hi Christian,
>>>> ERROR or higher, as the modifying transaction
>>>> IStatus.ERROR).
>>>> appear as decorations,
>>>> is something
>>>> modification gets
>>>> easily.
>>>> handled by on demand execution
>>>> constraints.
>>>> Regards,
>>>> /Radek
>>>> <atoulme@intalio.com> wrote:
>>>>> Hi Radek,
>>>>> shapes ?
>>>>> Radek Dvorak wrote:
>>>>>> Christian,
>>>>>> called at all?
>>>>>> /Radek
>>>>>> "Christian Dänekas"
>>>>>>> Hi Radek,
>>>>>>> use Diagram>Validate I guess the audits and constraints are
>>>>>>> correctly defined. But maybe I have to specify other things in
>>>>>>> missing?
>>>>>>> Greetings,
>>>>>>> Christian
>>>>>>> Radek Dvorak wrote:
>>>>>>>> Hi ,
>>>>>>>> is done by desing here.
>>>>>>>> in the GMF editor.
>>>>>>>> Regards,
>>>>>>>> /Radek
Previous Topic:Adding Object to a line
Next Topic:figure resize
Current Time: Fri Jul 18 22:36:07 EDT 2025
Powered by FUDForum. Page generated in 0.07713 seconds
