Home » Archived » XML Schema Definition (XSD) » xsd import
xsd import [message #75805] Wed, 17 September 2008 07:34 Go to next message
I keep getting a "ClassNotFoundException" whenever i try to
access the URIConverter through XSDResourceImpl(doLoad)
The eclipse version used is 3.3 and plugin for xsd is
org.eclipse.xsd.2.3.1 and org.eclipse.emf.ecore 2.1 and
org.eclipse.emf.common 2.1
Will it work for this configuration?
Can you please tell me the possible reasons for this error?
Re: xsd import [message #75838 is a reply to message #75805] Wed, 17 September 2008 10:18 Go to previous message
Gitanjali,
You need to match the numbers. XSD 2.3.x requires EMF 2.3.1.
Gitanjali Punj wrote:
> Hello,
Re: xsd import [message #603333 is a reply to message #75805] Wed, 17 September 2008 10:18 Go to previous message
Gitanjali,
> Hello,
Previous Topic:xsd import
Next Topic:xsd plugin
Current Time: Tue Jul 22 02:31:40 EDT 2025
Powered by FUDForum. Page generated in 0.05650 seconds
