Home » Archived » BIRT » Web Viewer of BIRT
Web Viewer of BIRT [message #75745] Tue, 20 September 2005 03:32 Go to next message
Originally posted by: ashish.nathani.ypoint.com
Hi All,
The web viewer which comes along with BIRT generates some web page when we
try to preview the report in HTML or PDF
I noticed that it generates some URL like this below:
http://127.0.0.0:63247/viewer/run?__report=c:\eclipse\worksp ace\MyFirst\new_report.rptdesign
What i did was from some other pc in the netork I gave a htt
http://<myip> :63247/viewer/run?__report=c:\eclipse\workspace\MyFirst\new_ report.rptdesign
This works !!!!, I can see the report from some other PC.
The only thing which happens is that the port number (63247) changes
everytime you restart your eclipse version.
Is there some way to prevent this ?
Ashish
Re: Web Viewer of BIRT [message #75865 is a reply to message #75745] Tue, 20 September 2005 10:00 Go to previous messageGo to next message
Ashish,
Download the standalone BIRT engine birt-runtime-1_0_1.zip
and deploy it to Tomcat or some other application server.
Move your report to the new application and it should work.
Jason Weathersby
BIRT PMC
"Ashish" <ashish.nathani@ypoint.com> wrote in message
news:dgoe36$rta$1@news.eclipse.org...
> Hi All,
> Ashish
Re: Web Viewer of BIRT [message #78256 is a reply to message #75745] Fri, 30 September 2005 17:59 Go to previous message
Yes. You can control the port number by preview prefernce setting. The
default port number is zero, which will be dynamically assigned by the
system.
Report developers can use this feature to share their works even before the
report is deployed.
-wenbin
> Hi All,
> Ashish
Previous Topic:ROM UserProperty structure
Next Topic:Error.TableItemProcessingError
Current Time: Mon Jul 21 21:56:26 EDT 2025
Powered by FUDForum. Page generated in 0.07613 seconds
