Home » Archived » M2M (model-to-model transformation) » [ATL] Changing the metaclass of an EObject
[ATL] Changing the metaclass of an EObject [message #75733] Tue, 04 March 2008 12:06 Go to next message
Originally posted by: rivera.lcc.uma.es
Hi all,
sorry for asking again, but I forgot to precede with [ATL] the topic of
my previous e-mail,
¿Is it possible to change the metaclass of an object with ATL after
creating it?
I want to transform models from one platform to Ecore, independently of
its metamodel. I would like something like creating an EObject for each
object of my platform, and assigning its class (something like
setEClass, that does not exist, contrary to getEClass) depending of some
information and a metamodel as another input for example
Thank you in advance,
Edu
Re: [ATL] Changing the metaclass of an EObject [message #76126 is a reply to message #75733] Fri, 07 March 2008 05:29 Go to previous messageGo to next message
Originally posted by: quentin.glineur.obeo.fr
--------------030109010301060009070204
Hi Jose,
I don't think there's a way to do what you want to. Model transformation
deals with fixed metamodels: In its spririt, ATL does not deal with
EObject handling but with the concept of model elements (i.e. typed
element whose type is described in a metamodel).
In you case dealing with an Ecore metamodel means you can only create
elements such as EClass, EReferences etc. And an EObject as only
operations (no structural feature) so nothing to set! Moreover, its
eSetClass() method call would raise an exception (as far as I know, this
is just for internal use).
Quentin
Jose E. Rivera a
Re: [ATL] Changing the metaclass of an EObject [message #76143 is a reply to message #76126] Fri, 07 March 2008 05:37 Go to previous messageGo to next message
--------------030807080900040607070702
Quentin,
I'd previously explained that he needs to decide up front which type of
target object to create, not create a plain old EObject and they try to
morph the type. Certainly such type morphing is supported for dynamic
models. After all, EFactoryImpl.basicCreate looks like this:
| *protected *EObject basicCreate(EClass eClass)
*return*
eClass.getInstanceClassName() == "java.util.Map$Entry" ?
*new *DynamicEObjectImpl.BasicEMapEntry<String, String>(eClass) :
*new *DynamicEObjectImpl(eClass);
Where the constructor just does
* Creates a dynamic EObject.
*public *DynamicEObjectImpl(EClass eClass)
*super*();
eSetClass(eClass);
But indeed generally you have to assume that an object has a fixed type
and that trying to change it after its been created by a factory is just
bad news.
Quentin Glineur wrote:
> Hi Jose,
> transformation deals with fixed metamodels: In its spririt, ATL does
> not deal with EObject handling but with the concept of model elements
> (i.e. typed element whose type is described in a metamodel).
> this is just for internal use).
> Quentin
> Jose E. Rivera a
Re: [ATL] Changing the metaclass of an EObject [message #76159 is a reply to message #76143] Fri, 07 March 2008 06:25 Go to previous message
Thank you both for your help :)
I can know the EClass of the object before creting it, but it will
depend on the souce model, and in an ATL Rule the classes of the target
elements to be created are fixed, that's why I asked.
Sorry Quentin for asking again the same question, but I wanted to know
if there was a "special" way to do it with ATL...
Ed Merks escribió:
> Quentin,
> *return*
> *super*();
> eSetClass(eClass);
> bad news.
>> Hi Jose,
>> Regards,
>> Quentin
>> Jose E. Rivera a écrit :
>>> Hi all,
>>> of my previous e-mail,
>>> creating it?
>>> of its metamodel. I would like something like creating an EObject for
>>> each object of my platform, and assigning its class (something like
>>> some information and a metamodel as another input for example
>>> Edu
Previous Topic:[ATL] NPE at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFModel.java:320)
Next Topic:[ATL]Transform UML Activity Diagram using ATL
Current Time: Tue Jul 15 20:07:57 EDT 2025
Powered by FUDForum. Page generated in 0.03169 seconds
