Merge exist project with CVS repository [message #75707] |
Mon, 14 July 2003 13:32  |
Hi, I am a new user of eclipse, when I create a new eclipse which point
to the exist project directory, it automatically recognize everything
like put classess in WEB-INF, which is great.
However, after I finalize things and setup the CVS repository, what I
see if only chectout a new copy to new directory. How can I tell eclipse
to checkout sources to existing source directory, so that I don't need
to create a new project?
Re: Merge exist project with CVS repository [message #76764 is a reply to message #76507] |
Wed, 16 July 2003 10:59  |
When you are ready to create a CVS module from an existing Project, you
should simply select the Project, right-click, and choose "Team > Share
Project..." Once you finish that, the existing Project in Eclipse will
be associated with the CVS repository.
HTH,
Eric
Eric Rizzo
Software Architect
Jibe, Inc.
http://www.jibeinc.com
FUDForum. Page generated in 0.07297 seconds
