Webapps in Equinox [message #75695] |
Thu, 26 October 2006 09:30  |
I installed the bundle org.eclipse.equinox.http.jetty and all its
required bundles.
If I install a webapp bundle, it must use the
org.eclipse.equinox.http.registry's extension point to define where
resources or servlets can be found.
But why does the jetty bundle knows that a new webapp is installed and
how did it get the informations about that webapp?
How can I define the jsp's location in a webapp? Is that feature already
supported?
Thanks for help!!!
Sabine
Re: Webapps in Equinox [message #75713 is a reply to message #75695] |
Thu, 26 October 2006 09:50   |
Originally posted by: ridcully560.yahoo.com
Hello Sabine,
sorry, can't help you with that one.
> supported?
I do it as follows:
> HttpContext commonContext = service.createDefaultHttpContext();
> Servlet adaptedJspServlet = new org.eclipse.equinox.jsp.jasper.ContextPathServletAdaptor(new org.eclipse.equinox.jsp.jasper.JspServlet(context.getBundle( ), "/WebContent"), "/jsp", "/WebContent");
> service.registerServlet("/jsp" + "/*.jsp", adaptedJspServlet, null, commonContext);
Where "/WebContent" is the top-directory where all my web-recources are
located. Actually I've got another directory called "jsp" inside that
one, but it seems that all subdirectories are scanned for JSPs.
And "/jsp" is the name under which the JSPs are available. So for example:
<YourProject>/WebContent/Main.jsp
http://localhost/jsp/Main.jsp
and
<YourProject>/WebContent/jsp-files/Main.jsp
http://localhost/jsp/jsp-files/Main.jsp
On http://www.eclipse.org/equinox/server/jsp_support.php you can
download and import a team project set. I think you need that one to get
the bundles that support JSPs.
Near the end of that page there's also a project for JSTL-support.
Hope that helps,
Johannes
Re: Webapps in Equinox [message #75729 is a reply to message #75713] |
Fri, 27 October 2006 04:46   |
Hello Johannes,
thanks for help!
But I have a question:
Where does the "HttpContext" and "service" came from?
Sabine
Johannes schrieb:
> Hello Sabine,
>> already supported?
> I do it as follows:
>> commonContext);
> and
> Hope that helps,
> Johannes
Re: Webapps in Equinox [message #75746 is a reply to message #75729] |
Fri, 27 October 2006 05:08   |
Hello Sabine,
> thanks for help!
I think I forgot something. I wrote a class extending ServiceTracker
(Following a tutorial from the EclipseCon(?), I think - but I don't have
that one here anymore. I'll post where it can be found when I get it again).
> import javax.servlet.Servlet;
> import org.osgi.framework.BundleContext;
> import org.osgi.framework.ServiceReference;
> import org.osgi.service.http.HttpContext;
> import org.osgi.service.http.HttpService;
> import org.osgi.util.tracker.ServiceTracker;
> public class MainPluginTracker extends ServiceTracker {
> private String dir;
> private String alias;
> public MainPluginTracker(BundleContext context, String alias, String dir) {
> super(context, HttpService.class.getName(), null);
> this.dir = dir;
> this.alias = alias;
> public Object addingService(ServiceReference reference) {
> final HttpService service = (HttpService) context.getService(reference);
> try {
> Servlet adaptedJspServlet = new org.eclipse.equinox.jsp.jasper.ContextPathServletAdaptor(new org.eclipse.equinox.jsp.jasper.JspServlet(context.getBundle( ), dir), alias, dir);
> service.registerServlet(alias + "/*.jsp", adaptedJspServlet, null, commonContext);
> } catch (Exception e) {
> // TODO Auto-generated catch block
> e.printStackTrace();
> return service;
And I use that class in the BundleActivator start()-Method:
> httpServiceTracker = new MainPluginTracker(context, "/jsp", "/WebContent");
> httpServiceTracker.open();
As you can see, I added the two variables "alias" and "dir", to use that
Tracker with different plugins.
Hope it is a bit clearer now. Sorry, I thought you could use the code I
posted yersterday in the Activator, but that don't seem to work.
Johannes
Re: Webapps in Equinox [message #78335 is a reply to message #75695] |
Sat, 02 December 2006 23:34  |
Originally posted by: skaegi.sympatico.ca
Hi Sabine,
comments inlined.
1) org.eclipse.equinox.http.jetty exposes an OSGi Http Service.
2) org.eclipse.equinox.http.registry uses the extension registry to listens
for servlet and resource extensions and then will handle the registering in
all available Http Service instances.
> supported?
JSPs (and taglibs) are found through the ServletContext.getResource methods
so it's a matter of setting up your resource paths correctly. The OSGi Http
Service creates a ServletContext from the getResource methods in the
HttpContext. In addition to servlets and resources there is another
extension point in org.eclipse.equinox.http.registry which specifically
deals with setting up an httpcontext which you might look at.
You can take a look at JSP support here
There is no direct integration of this support in http.registry currently
however it's a planned item and will be added shortly.
-Simon
> Thanks for help!!!
> Best regards,
> Sabine
FUDForum. Page generated in 0.33464 seconds
