Home » Eclipse Projects » GEF » TreeViewer/TreeEditPart is not lazy
TreeViewer/TreeEditPart is not lazy [message #75692] Tue, 15 April 2003 13:09 Go to next message
Originally posted by: Hermann.Weindl.mind8.com.no.spam
Is there any particular reason why the implementation of
TreeViewer/TreeEditPart is based on org.eclipse.swt.widgets.Tree and not
on org.eclipse.jface.viewers.TreeViewer?
--hermann
Re: TreeViewer/TreeEditPart is not lazy [message #75709 is a reply to message #75692] Tue, 15 April 2003 13:43 Go to previous message
You are not required to use GEF's TreeViewer. You can use a JFace
treeviewer for your outline if you wish.
You can also extend AbstractTreeEditPart such that it calls refreshChildren
only when the TreeItem is expanded.
The JFace treeviewer is read-only. GEF's TreeViewer is designed around Tools
and EditParts, which produce commands which change the model.
"Hermann Weindl" <Hermann.Weindl@mind8.com.no.spam> wrote in message
news:3E9C3CC2.1010702@mind8.com.no.spam...
> --hermann
Previous Topic:[ANN] GEF 2.2 planning underway
Next Topic:Exceptions in draw2d-standalone
Current Time: Fri Jul 18 00:04:34 EDT 2025
Powered by FUDForum. Page generated in 0.39912 seconds
