Home » Language IDEs » C / C++ IDE (CDT) » C-Build path
C-Build path [message #75682] Tue, 15 July 2003 15:45 Go to next message
When running make file from within C-Build in the CDT plug-in for
Eclipse (on Win98) it doesn't appear to pay attention to the defined DOS
Path:
C:\msys\1.0\bin\make -k clean
rm -rf hello.exe main.o
make: rm: Command not found
make: *** [clean] Error 127
The makefile works fine when run from a DOS prompt.
How do you get C-Build to use the DOS Path such that it can find the
compilation executables?
Matt
http://www.strontiumdog.net
Re: C-Build path [message #75699 is a reply to message #75682] Tue, 15 July 2003 16:29 Go to previous messageGo to next message
> Path:
Have you been adding C:\msys\1.0\bin to your PATH variable?
Did you restart Eclipse after changing the PATH variable?
Add the MinGW binary-path and the MSYS binary path both to PATH.
You'll need to restart Eclipse if it had been running at this point.
Afterwards, Eclipse should recognise it.
> Matt
Re: C-Build path [message #75988 is a reply to message #75699] Wed, 16 July 2003 13:29 Go to previous messageGo to next message
Indeed I have:
C:\WINDOWS>path
PATH=C:\MSYS\1.0\BIN;C:\MINGW\BIN
Which is clearly correct as the make runs fine from the DOS Prompt:
C:\HelloWorld>make -k clean all
g++ -g -c -o main.o main.cpp
g++ -g -o hello.exe main.o
Eclipse just doesn't appear to be using the PATH environment variable
(it only gets this far because I supply the path to make.exe in the
Build Command)
C:\msys\1.0\bin\make -k clean all
make: g++: Command not found
make: *** [all] Error 127
>> DOS Path:
>> Matt
Re: C-Build path [message #76016 is a reply to message #75988] Wed, 16 July 2003 15:21 Go to previous messageGo to next message
Originally posted by: ashes999.rogers.com
As far as I know, Eclipse doesn't pay attention to the PATH variable. Just
add the path in when you specify what your bulid command is in the project
properties.
--Ashiq
"Matt Seaborn" <Matt@strontiumdog.net> wrote in message
news:bf4208$o1h$1@eclipse.org...
> Indeed I have:
> C:\WINDOWS>path
> Build Command)
> >> DOS Path:
> >> Matt
Re: C-Build path [message #76446 is a reply to message #76016] Sun, 20 July 2003 05:02 Go to previous messageGo to next message
As can be seen from the example below, that enables Eclipse to find the
make.exe, but doesn't allow the make.exe to locate the g++.exe
> properties.
> --Ashiq
>>Indeed I have:
>>C:\WINDOWS>path
>>Build Command)
>>>>DOS Path:
>>>>Matt
Re: C-Build path [message #76554 is a reply to message #76446] Wed, 23 July 2003 07:54 Go to previous message
Originally posted by: no.mail.com
Tried it too, but no go on win me.
it just works 4 me on win nt and xp.
path-lookup in cdt is imho broken under win 9X
> > properties.
> > --Ashiq
> >>Indeed I have:
> >>C:WINDOWS>path
> >>PATH=C:MSYS1.0BIN;C:MINGWBIN
> >>C:HelloWorld>make -k clean all
> >>Build Command)
> >>C:msys1.0binmake -k clean all
> >>>>DOS Path:
> >>>Have you been adding C:msys1.0bin to your PATH variable?
> >>>>Matt
Previous Topic:CDT: Ant Build Tutorials
Next Topic:someone pls relpy back... if this can be done or not???
Current Time: Tue Jul 22 08:27:58 EDT 2025
Powered by FUDForum. Page generated in 0.03783 seconds
