Home » Archived » M2M (model-to-model transformation) » [ATL] [BUG?] programmatic launch produces ATL transformation errors
[ATL] [BUG?] programmatic launch produces ATL transformation errors [message #75662] |
Mon, 03 March 2008 06:04  |
Hi guys,
I have a weird problem here, i'm assuming its a bug.
When I launch my ATL transformation manually it works perfectly well
without any errors.
Launching the same whole with the correct paths etc produces errors like:
SEVERE: ****** BEGIN Stack Trace
SEVERE: message: ERROR: could not find operation getTemplateClass on
UML!Class having supertypes: [UML!BehavioredClassifier,
UML!EncapsulatedClassifier, OclType, OclAny] (including Java operations)
Here is a header of this operation:
helper context UML!Class def: getTemplateClass(): UML!Class
My guess is that the problem is with this context. When i replace the
function inline it stops complaining.
thanks in advance.
Aram Hovsepyan.
Re: [ATL] [BUG?] programmatic launch produces ATL transformation errors [message #75877 is a reply to message #75802] |
Wed, 05 March 2008 07:38   |
Hey Quentin,
How can I check on that? I think you are right. Somehow the UML metamodel
is not loaded correctly. In some other helper functions I have a check
oclIsTypeOf(UML!Class) and it returns false while manual invokation results
in true.
The UML metamodel is loaded though because i tried changing some paths and
ATL then starts giving NullPointer exceptions.
I would appreciate if you could send me the code samples you use to startup
the atl code. I'm using a 3rd party written AtlStarter and its not very
clear to me.
Thanks in advance.
Aram.
Quentin Glineur wrote:
> Are you sure that the UML metamodel is correctly loaded by your
> programmatic launching?
> (I had a similar problem for MOF)
> Quentin GLINEUR
> Aram Hovsepyan a écrit :
>> Hey guys,
>> Could anyone tell me at least if I should bother looking into
>> some errors
>> in my AtlStarter or should I just wait for a bug fix?
>> To remind - my transformation works perfectly when i invoke it
>> manually.
>> When i call it programmatically from my plugin it gives an error.
>> thnx
>> Aram Hovsepyan wrote:
>>> Hi guys,
>>> well
>>> without any errors.
>>> errors like:
>>> getTemplateClass on UML!Class having supertypes:
>>> [UML!BehavioredClassifier, UML!EncapsulatedClassifier, OclType, OclAny]
>>> replace the
>>> thanks in advance.
>>> Regards,
>>> Aram Hovsepyan.
Re: [ATL] [BUG?] programmatic launch produces ATL transformation errors [message #75894 is a reply to message #75877] |
Wed, 05 March 2008 08:31   |
I managed to limit the scope of the problem. Here is a sample rule
-- Rule to copy classes
rule class2class {
from i : UML!Class (
thisModule.elementsToCopy()->includes(i)
to o : UML!Class mapsTo i
name <- i.name,
do
if(o.oclIsTypeOf(UML!Class))
'type is recognized'.println();
else
'should not happen'.println();
When invoked manually i get of course the type is recognized message. When
invoked programmatically i get the 'should not happen' output.
Help is really appreciated.
Thnx
> Hey Quentin,
> metamodel
> results in true.
> paths and
> to startup
> clear to me.
> Thanks in advance.
> Aram.
>> Quentin GLINEUR
>>> Hey guys,
>>> some errors
>>> manually.
>>> thnx
>>>> Hi guys,
>>>> well
>>>> without any errors.
>>>> errors like:
>>>> replace the
>>>> thanks in advance.
>>>> Regards,
>>>> Aram Hovsepyan.
Re: [ATL] [BUG?] programmatic launch produces ATL transformation errors [message #75911 is a reply to message #75894] |
Wed, 05 March 2008 08:49   |
Originally posted by: quentin.glineur.obeo.fr
--------------050700060809000409060702
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi, you may have a look inside the QVT Relations source code (from the CVS).
The RelationsCompiler has quite an easy code to launch a transformation.
Quentin
> rule class2class {
> name <- i.name,
> do
> else
> Thnx
>> Hey Quentin,
>> metamodel
>> results in true.
>> paths and
>> to startup
>> clear to me.
>> Thanks in advance.
>> Regards,
>> Aram.
>>> Hi,
>>> Quentin GLINEUR
>>>> Hey guys,
>>>> some errors
>>>> manually.
>>>> thnx
>>>>> Hi guys,
>>>>> well
>>>>> without any errors.
>>>>> errors like:
>>>>> replace the
>>>>> thanks in advance.
>>>>> Regards,
>>>>> Aram Hovsepyan.
Content-Type: text/x-vcard; charset=utf-8;
name="quentin_glineur.vcf"
Content-Disposition: attachment;
filename="quentin_glineur.vcf"
YmVnaW46dmNhcmQNCmZuOlF1ZW50aW4gR0xJTkVVUg0KbjpHTElORVVSO1F1 ZW50aW4NCm9y
ZzpPYmVvIC0gTW9kZWwgRHJpdmVuIENvbXBhbnk7UmVzZWFyY2ggYW5kIERl dmVsb3BtZW50
DQphZHI7cXVvdGVkLXByaW50YWJsZTo7OzIgcnVlIFJvYmVydCBTY2h1bWFu bjtSZXo9QzM9
QTk7OzQ0NDAwO0ZyYW5jZQ0KZW1haWw7aW50ZXJuZXQ6cXVlbnRpbi5nbGlu ZXVyQG9iZW8u
ZnINCnRpdGxlOk1EQSBDb25zdWx0YW50DQp0ZWw7d29yazorMzMyIDUxIDEz IDU0IDE4DQp4
LW1vemlsbGEtaHRtbDpUUlVFDQp1cmw6aHR0cDovL3d3dy5vYmVvLmZyDQp2 ZXJzaW9uOjIu
MQ0KZW5kOnZjYXJkDQoNCg==
--------------050700060809000409060702--
Re: [ATL] [BUG?] programmatic launch produces ATL transformation errors [message #75931 is a reply to message #75911] |
Wed, 05 March 2008 09:09   |
I think my UML metamodel is loaded fine.
Somehow the check with oclIsKindOf(UML!Class) does work. I am not familiar
with the internals of ATL but if it uses also internally the oclIsTypeOf to
match the context of a helper this might be the whole problem.
> CVS).
> Quentin
>> rule
>> rule class2class {
>> name <- i.name,
>> do
>> else
>> When invoked programmatically i get the 'should not happen' output.
>> Thnx
>>> Hey Quentin,
>>> metamodel
>>> results in true.
>>> paths and
>>> to startup
>>> clear to me.
>>> Thanks in advance.
>>> Regards,
>>> Aram.
>>>> Hi,
>>>> Quentin GLINEUR
>>>>> Hey guys,
>>>>> some errors
>>>>> manually.
>>>>> thnx
>>>>>> Hi guys,
>>>>>> perfectly well
>>>>>> without any errors.
>>>>>> errors like:
>>>>>> [OclAny]
>>>>>> replace the
>>>>>> thanks in advance.
>>>>>> Regards,
>>>>>> Aram Hovsepyan.
Re: [ATL] [BUG?] programmatic launch produces ATL transformation errors [message #75959 is a reply to message #75931] |
Wed, 05 March 2008 09:24   |
--------------010209050902080103020704
Answer follows up.
Sorry to insist but what make you think so? (Can you give excerpt of
your code?) The metamodel is not loaded fine if it's metamodel is not
properly loaded.
No, oclIskindOf does not use oclIsTypeOf! It should come from somewhere
else!
>> CVS).
>> Regards,
>> Quentin
>>> Hi,
>>> rule
>>> rule class2class {
>>> name <- i.name,
>>> do
>>> else
>>> Thnx
>>>> Hey Quentin,
>>>> metamodel
>>>> results in true.
>>>> paths and
>>>> to startup
>>>> clear to me.
>>>> Thanks in advance.
>>>> Regards,
>>>> Aram.
>>>>> Hi,
>>>>> Quentin GLINEUR
>>>>>> Hey guys,
>>>>>> some errors
>>>>>> manually.
>>>>>> thnx
>>>>>>> Hi guys,
>>>>>>> perfectly well
>>>>>>> without any errors.
>>>>>>> errors like:
>>>>>>> [OclAny]
>>>>>>> replace the
>>>>>>> thanks in advance.
>>>>>>> Regards,
>>>>>>> Aram Hovsepyan.
--------------010209050902080103020704--
Re: [ATL] [BUG?] programmatic launch produces ATL transformation errors [message #75976 is a reply to message #75959] |
Wed, 05 March 2008 09:53   |
Hi Quentin,
Here is an excerpt from my code where i launch the transformation with some
input models.
Map<String, ASMModel> models = new HashMap<String, ASMModel>();
HashMap<String, URL> libraries = new HashMap<String, URL>();
AtlModelHandler amh = getDefaultHandler();
ASMModel metaModel = ((AtlUML2ModelHandler) amh).loadModel("UML",
amh.getMof(), "uri:http://www.eclipse.org/uml2/2.1.0/UML");
ASMModel concern1 = ((AtlUML2ModelHandler)amh).loadModel("CONCERN1",
metaModel,
URI.createURI(" file://home/barri/workspace-grecco/LabApplication/lab_applic ation.uml"));
ASMModel concern2 = ((AtlUML2ModelHandler)amh).loadModel("CONCERN2",
metaModel,
URI.createURI(" file://home/barri/workspace/org.kuleuven.grecco_view/concern _library/application_firewall.uml"));
ASMModel mapping = ((AtlUML2ModelHandler)amh).loadModel("MAPPING",
metaModel,
URI.createURI(" file://home/barri/workspace-grecco/LabApplication/Mapping.um l"));
ASMModel outputModel =
amh.newModel("TARGET", " file://home/barri/workspace-grecco/LabApplication/Target.uml",
metaModel);
outputModel.setIsTarget(true);
libraries.put("LIB", new
URL("file:/home/barri/workspace/GReCCo/helpers_plugin.asm"));
models.put("CONCERN1", concern1);
models.put("CONCERN2", concern2);
models.put("MAPPING", mapping);
models.put("UML", metaModel);
models.put("TARGET", outputModel);
URL tf = new URL("file:/home/barri/workspace/GReCCo/grecco_plugin.asm");
AtlLauncher.getDefault().launch(tf, libraries, models,
Collections.EMPTY_MAP, new ArrayList(), Collections.EMPTY_MAP);
What I mean about oclistypeof and ocliskindof is the following:
rule class2class {
do
print('something')
thisModule.model.packagedElement <- o;
when i launch the atl like this there is never output. if i use ocliskindof
instead, there is always output.
> Answer follows up.
> properly loaded.
>> familiar
>> to match the context of a helper this might be the whole problem.
> else!
>>> CVS).
>>> Regards,
>>> Quentin
>>>> Hi,
>>>> rule
>>>> rule class2class {
>>>> name <- i.name,
>>>> do
>>>> else
>>>> Thnx
>>>>> Hey Quentin,
>>>>> UML metamodel
>>>>> results in true.
>>>>> some paths and
>>>>> use to startup
>>>>> very clear to me.
>>>>> Thanks in advance.
>>>>> Regards,
>>>>> Aram.
>>>>>> Hi,
>>>>>> Quentin GLINEUR
>>>>>>> Hey guys,
>>>>>>> into some errors
>>>>>>> it manually.
>>>>>>> thnx
>>>>>>>> Hi guys,
>>>>>>>> perfectly well
>>>>>>>> without any errors.
>>>>>>>> [OclAny]
>>>>>>>> replace the
>>>>>>>> thanks in advance.
>>>>>>>> Regards,
>>>>>>>> Aram Hovsepyan.
Re: [ATL] [BUG?] programmatic launch produces ATL transformation errors [message #76060 is a reply to message #75976] |
Thu, 06 March 2008 06:09   |
--------------070801000400090201050902
How do get the AtlModelHandler? i.e. what does getDefaultHandler() do?
> Hi Quentin,
> input models.
> metaModel,
> metaModel,
> metaModel,
> metaModel);
> rule class2class {
> do
> print('something')
>> Answer follows up.
>>> Hi,
>> properly loaded.
>>> familiar
>> else!
>>>> CVS).
>>>> Regards,
>>>> Quentin
>>>>> Hi,
>>>>> rule
>>>>> rule class2class {
>>>>> name <- i.name,
>>>>> do
>>>>> else
>>>>> Thnx
>>>>>> Hey Quentin,
>>>>>> UML metamodel
>>>>>> results in true.
>>>>>> some paths and
>>>>>> use to startup
>>>>>> very clear to me.
>>>>>> Thanks in advance.
>>>>>> Regards,
>>>>>> Aram.
>>>>>>> Hi,
>>>>>>> Quentin GLINEUR
>>>>>>>> Hey guys,
>>>>>>>> into some errors
>>>>>>>> it manually.
>>>>>>>> thnx
>>>>>>>>> Hi guys,
>>>>>>>>> perfectly well
>>>>>>>>> without any errors.
>>>>>>>>> [OclAny]
>>>>>>>>> replace the
>>>>>>>>> thanks in advance.
>>>>>>>>> Regards,
>>>>>>>>> Aram Hovsepyan.
>> Regards,
--------------070801000400090201050902--
Re: [ATL] [BUG?] programmatic launch produces ATL transformation errors [message #76076 is a reply to message #76060] |
Thu, 06 March 2008 07:31   |
a yea, i forgot. here is the piece:
public static AtlModelHandler getDefaultHandler()
AtlModelHandler amh = AtlUML2ModelHandler.getDefault("UML2");
return amh;
regards,
Aram.
> Regards
>> Hi Quentin,
>> with some
>> input models.
>> metaModel,
>> metaModel,
>> metaModel,
>> metaModel);
>> rule class2class {
>> do
>> print('something')
>> ocliskindof
>>> Answer follows up.
>>>> Hi,
>>> properly loaded.
>>>> not familiar
>>>> oclIsTypeOf to match the context of a helper this might be the whole
>>>> problem.
>>> else!
>>>>> CVS).
>>>>> transformation.
>>>>> Regards,
>>>>> Quentin
>>>>>> Hi,
>>>>>> rule
>>>>>> rule class2class {
>>>>>> name <- i.name,
>>>>>> do
>>>>>> else
>>>>>> Thnx
>>>>>>> Hey Quentin,
>>>>>>> UML metamodel
>>>>>>> check oclIsTypeOf(UML!Class) and it returns false while manual
>>>>>>> invokation results in true.
>>>>>>> some paths and
>>>>>>> use to startup
>>>>>>> very clear to me.
>>>>>>> Thanks in advance.
>>>>>>> Regards,
>>>>>>> Aram.
>>>>>>>> Hi,
>>>>>>>> Quentin GLINEUR
>>>>>>>>> Hey guys,
>>>>>>>>> into some errors
>>>>>>>>> invoke it manually.
>>>>>>>>> thnx
>>>>>>>>>> Hi guys,
>>>>>>>>>> perfectly well
>>>>>>>>>> without any errors.
>>>>>>>>>> [OclAny]
>>>>>>>>>> replace the
>>>>>>>>>> thanks in advance.
>>>>>>>>>> Regards,
>>>>>>>>>> Aram Hovsepyan.
>>> Regards,
Re: [ATL] [BUG?] programmatic launch produces ATL transformation errors [message #76093 is a reply to message #76076] |
Fri, 07 March 2008 03:59   |
--------------090402050904020000070003
Hi Aram,
I think that your model handler may have no registry (MOF) instanciated.
Indeed, the method createMOF() is called in the AtlUML2ModelHandler
constructor.
Try to use an AtlUML2ModelHandler instanciated by:
AtlUML2ModelHandler aumh = new AtlUML2ModelHandler()
Quentin
> return amh;
> regards,
> Aram.
>> Regards
>>> Hi Quentin,
>>> with some
>>> input models.
>>> metaModel,
>>> metaModel,
>>> metaModel,
>>> metaModel);
>>> rule class2class {
>>> do
>>> print('something')
>>> ocliskindof
>>>> Answer follows up.
>>>>> Hi,
>>>> properly loaded.
>>>>> not familiar
>>>>> problem.
>>>> else!
>>>>>> CVS).
>>>>>> transformation.
>>>>>> Regards,
>>>>>> Quentin
>>>>>>> Hi,
>>>>>>> rule
>>>>>>> rule class2class {
>>>>>>> name <- i.name,
>>>>>>> do
>>>>>>> else
>>>>>>> Thnx
>>>>>>>> Hey Quentin,
>>>>>>>> UML metamodel
>>>>>>>> some paths and
>>>>>>>> use to startup
>>>>>>>> very clear to me.
>>>>>>>> Thanks in advance.
>>>>>>>> Regards,
>>>>>>>> Aram.
>>>>>>>>> Hi,
>>>>>>>>> Quentin GLINEUR
>>>>>>>>>> Hey guys,
>>>>>>>>>> into some errors
>>>>>>>>>> invoke it manually.
>>>>>>>>>> thnx
>>>>>>>>>>> Hi guys,
>>>>>>>>>>> perfectly well
>>>>>>>>>>> without any errors.
>>>>>>>>>>> [OclAny]
>>>>>>>>>>> replace the
>>>>>>>>>>> thanks in advance.
>>>>>>>>>>> Regards,
>>>>>>>>>>> Aram Hovsepyan.
>>>> Regards,
--------------090402050904020000070003--
Re: [ATL] [BUG?] programmatic launch produces ATL transformation errors [message #76111 is a reply to message #76093] |
Fri, 07 March 2008 05:26   |
Hi Quentin,
Thanks for the reply but it doesn't help. I've changed the method
implementation to
amh = new AtlUML2ModelHandler();
but still the same errors. Types are somehow not recognized. Only
oclIsKindOf recognizes the types.
I've managed to create a workaround by using formal parameters in all my
atl helpers instead of using context variables.
Any other ideas? I have to give a demo next thursday and a fix by then
would be more than appreciated.
Aram.
> Hi Aram,
> constructor.
> Quentin
>> AtlUML2ModelHandler.getDefault("UML2"); return amh;
>> regards,
>> Aram.
>>> Hi,
>>> Regards
>>>> Hi Quentin,
>>>> input models.
>>>> metaModel,
>>>> metaModel,
>>>> metaModel,
>>>> metaModel);
>>>> URL tf = new
>>>> rule class2class {
>>>> do
>>>> print('something')
>>>> ocliskindof
>>>>> Answer follows up.
>>>>>> Hi,
>>>>> properly loaded.
>>>>>> not familiar
>>>>>> problem.
>>>>> somewhere else!
>>>>>>> the CVS).
>>>>>>> transformation.
>>>>>>> Regards,
>>>>>>> Quentin
>>>>>>>> Hi,
>>>>>>>> sample rule
>>>>>>>> rule class2class {
>>>>>>>> name <- i.name,
>>>>>>>> do
>>>>>>>> else
>>>>>>>> message. When invoked programmatically i get the 'should not
>>>>>>>> happen' output.
>>>>>>>> Thnx
>>>>>>>>> Hey Quentin,
>>>>>>>>> the UML metamodel
>>>>>>>>> you use to startup
>>>>>>>>> very clear to me.
>>>>>>>>> Thanks in advance.
>>>>>>>>> Regards,
>>>>>>>>> Aram.
>>>>>>>>>> Hi,
>>>>>>>>>> Quentin GLINEUR
>>>>>>>>>>> Hey guys,
>>>>>>>>>>> into some errors
>>>>>>>>>>> invoke it manually.
>>>>>>>>>>> error.
>>>>>>>>>>> thnx
>>>>>>>>>>>> Hi guys,
>>>>>>>>>>>> perfectly well
>>>>>>>>>>>> without any errors.
>>>>>>>>>>>> [OclAny]
>>>>>>>>>>>> i replace the
>>>>>>>>>>>> thanks in advance.
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Aram Hovsepyan.
>>>>> Regards,
Re: [ATL] [BUG?] programmatic launch produces ATL transformation errors [message #85992 is a reply to message #75662] |
Mon, 07 July 2008 03:31   |
Back to this problem,
Still not solved. This is the cause as pointed out by Quentin, however, I
guess he is not available at the moment.
"The problem seems to come from the UML driver. Indeed, ATL deals with its
own model elements.
When it handles UML elements, it creates ASMUMLModelElement instances. For
those, their supertypes are not registered.
Therefore, as you define operations on their supertypes, the ATL VM is
unable to find the correct operation."
Can I expect a solution in the near future or should I try to solve it
another way?
thnx
> Hi guys,
> well
> without any errors.
> errors like:
> on UML!Class having supertypes: [UML!BehavioredClassifier,
> the
> thanks in advance.
> Aram Hovsepyan.
Aram Hovsepyan
Distrinet research group
Katholieke Universiteit Leuven
Re: [ATL] [BUG?] programmatic launch produces ATL transformation errors [message #86099 is a reply to message #85992] |
Tue, 08 July 2008 09:15   |
Originally posted by: monnet2.etu.unige.ch
I guess I am faced to a similar problem, but working with EMF Ecore meta
models.
I defined an ATL file for doing the union of two meta models based on
Ecore. On the Eclipse ATL plugin all works fine.
My transformation take as inputs:
- the left meta model MOFLeft which conforms to EMF Ecore
- the right meta model MOFRight which conforms to EMF Ecore
And it produces as output a composed meta model (which conforms to EMF
Ecore too) with the union of content of both meta models.
But launching it from Java with the AtlLauncher I get the following error
message (with similar "could not find operation allInstancesFrom on
MOFLeft!EClass having supertypes: [MOFLeft!EClassifier, OclType, OclAny]"
type of message):
Launcher info:
Jul 8, 2008 2:29:25 PM org.eclipse.m2m.atl.engine.vm.SimpleDebugger error
SEVERE: message: ERROR: could not find operation allInstancesFrom on
Jul 8, 2008 2:29:25 PM org.eclipse.m2m.atl.engine.vm.ExecEnv
printStackTrace
SEVERE: A.main() : ??#22 null
printStackTrace
SEVERE: local variables = {self=union_execute_metamodel_transformation :
ASMModule}
printStackTrace
SEVERE: local stack = []
printStackTrace
SEVERE: A.__matcher__() : ??#3 null
printStackTrace
ASMModule}
printStackTrace
printStackTrace
SEVERE: A.__matchCLASSLeft() : ??#9 null
printStackTrace
ASMModule}
printStackTrace
SEVERE: local stack = [MOFLeft!EClass, Sequence {}]
SEVERE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to allow
continuation after errors).
Jul 8, 2008 2:29:25 PM org.eclipse.m2m.atl.engine.AtlLauncher launch
SEVERE: ERROR: could not find operation allInstancesFrom on MOFLeft!EClass
having supertypes: [MOFLeft!EClassifier, OclType, OclAny] (including Java
operations)
java.lang.RuntimeException: ERROR: could not find operation
allInstancesFrom on MOFLeft!EClass having supertypes:
[MOFLeft!EClassifier, OclType, OclAny] (including Java operations)
org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:195)
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:95)
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:91)
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.invok e(ASMEMFModelElement.java:700)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:240)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:171)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:143)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:101)
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:299)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:169)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:111)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:87)
at UnionCOP.process(UnionCOP.java:104)
at MMComposition.process(MMComposition.java:28)
at Main.main(Main.java:47)
Any idea on how to solve this? Thank you in advance for any help.
Re: [ATL] [BUG?] programmatic launch produces ATL transformation errors [message #86129 is a reply to message #86099] |
Tue, 08 July 2008 10:22   |
Hey Xavier,
I am not sure you have the same problem. I get errors only with the ATL
operations that I define myself, never with the internal operations such as
allInstancesFrom.
regards,
Aram.
Xavier Monnet wrote:
> Hello,
> models.
> type of message):
> Launcher info:
> printStackTrace
> printStackTrace
> ASMModule}
> printStackTrace
> printStackTrace
> printStackTrace
> ASMModule}
> printStackTrace
> printStackTrace
> printStackTrace
> ASMModule}
> printStackTrace
> operations)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Aram Hovsepyan
Re: [ATL] [BUG?] programmatic launch produces ATL transformation errors [message #86144 is a reply to message #86129] |
Tue, 08 July 2008 15:50  |
Oh yes, sorry, you are right.
I saw the "could not find operation" and "having supertypes:" in the error
message and as you were working with UML models I thaugth it was similar.
But it is not.
Anyway, if someone has any experience or idea on what I am doing wrong, it
would be very apreciated as I am not getting how I can solve this issue.
Xavier.
> Hey Xavier,
ATL
> allInstancesFrom.
> regards,
> Aram.
>> Hello,
>> models.
>> type of message):
>> Launcher info:
>> printStackTrace
>> printStackTrace
>> ASMModule}
>> printStackTrace
>> printStackTrace
>> printStackTrace
>> ASMModule}
>> printStackTrace
>> printStackTrace
>> printStackTrace
>> ASMModule}
>> printStackTrace
>> operations)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Current Time: Mon Jul 21 21:54:45 EDT 2025
Powered by FUDForum. Page generated in 0.08050 seconds
