Home » Eclipse Projects » Eclipse Platform » catching eclipse close event
catching eclipse close event [message #75548] Mon, 16 June 2003 10:50 Go to next message
Originally posted by: anthony.saucet.freesbee.fr
In my perspective I'm only using views and I would like to listen an
event: when eclipse shuts down.
No pb when a view is being closed, I 've added a partListener.
But when eclipse is being closed I want to catch the event and do some
things before any actions done by eclipse.
does anybody know how to do?
thx
anthony
Re: catching eclipse close event [message #76185 is a reply to message #75548] Tue, 17 June 2003 07:33 Go to previous messageGo to next message
You may try to overwrite Plugin.shutdown() method in your plug-in class. It
is called when eclipse is going to close.
Another possible option is to listen for windowClosed event, for this
you'll have to add window listener to the IWorkbench instance
On Mon, 16 Jun 2003 14:50:21 +0000 (UTC), anthony
> thx
> anthony
best regards,
alexander kitaev
Re: catching eclipse close event [message #78522 is a reply to message #76185] Thu, 19 June 2003 13:12 Go to previous message
could you explain me the process when eclipse is shutting down cause
something is not working.
I've overwritten shutdown() but to close the views I need to get them,
then if the views are not null, close them. but I can't get the views.
here's the code:
public void shutdown(){
paramV = (ParamView) PlatformUI.getWorkbench()
.getActiveWorkbenchWindow().getActivePage()
.findView("com.itlity.luciol.tree.ParameterView");
winPage = LaunchXML.winPage;
if (paramV != null) winPage.hideView(paramV);
anthony
> > thx
> > anthony
> best regards,
> alexander kitaev
Previous Topic:Problems during startup;Check .log file
Next Topic:Major Problem with IResourceChangeListener and Import
Current Time: Mon Jul 28 16:35:54 EDT 2025
Powered by FUDForum. Page generated in 0.03393 seconds
