Home » Eclipse Projects » Remote Application Platform (RAP) » Problem in Progress Bar
Problem in Progress Bar [message #75545] |
Tue, 26 February 2008 06:44  |
Originally posted by: cheney_chen.i-len.com
hi,
Some problem in RAP Demo Progress Bar.
Steps to reproduce:
1. Download the RAP Demo from CVS.
2. Launch the RAP Demo and Switch to Planning Perspective.
3. Click the "Start Job With Dialog" action,When the Progress Bar is
running(the percent of the task isn't complete),refresh the Browser then
relaunch the application.
4. Switch to the eclipse,in eclipse console view,you can see the Exception
information:
osgi> Feb 26, 2008 7:33:43 PM org.mortbay.http.HttpServer doStart
INFO: Version Jetty/5.1.x
Feb 26, 2008 7:33:44 PM org.mortbay.util.Container start
INFO: Started org.mortbay.jetty.servlet.ServletHandler@1b49105b
INFO: Started HttpContext[/,/]
Feb 26, 2008 7:33:44 PM org.mortbay.http.SocketListener start
INFO: Started SocketListener on 0.0.0.0:40066
INFO: Started org.mortbay.http.HttpServer@580eac5a
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:1553)
at org.eclipse.swt.SWT.error(SWT.java:1473)
at org.eclipse.swt.SWT.error(SWT.java:1444)
at org.eclipse.swt.widgets.Widget.error(Widget.java:767)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:710)
at org.eclipse.swt.widgets.ProgressBar.getSelection(ProgressBar .java:151)
org.eclipse.jface.dialogs.ProgressIndicator.worked(ProgressI ndicator.java:119)
org.eclipse.jface.dialogs.ProgressIndicator.sendRemainingWor k(ProgressIndicator.java:100)
org.eclipse.jface.dialogs.ProgressMonitorDialog$ProgressMoni tor.done(ProgressMonitorDialog.java:182)
org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog$4 .done(ProgressMonitorJobsDialog.java:361)
org.eclipse.ui.internal.progress.ProgressMonitorFocusJobDial og$8.run(ProgressMonitorFocusJobDialog.java:244)
org.eclipse.ui.internal.progress.ProgressMonitorFocusJobDial og$10.run(ProgressMonitorFocusJobDialog.java:319)
org.eclipse.rwt.internal.lifecycle.UICallBackManager$Runnabl eBase.run(UICallBackManager.java:51)
org.eclipse.rwt.internal.lifecycle.UICallBackManager.process RunnablesInUIThread(UICallBackManager.java:157)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.afterPhaseEx ecution(RWTLifeCycle.java:369)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.continueLife Cycle(RWTLifeCycle.java:183)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.sleep(RWTLif eCycle.java:269)
at org.eclipse.swt.widgets.Display.sleep(Display.java:703)
org.eclipse.ui.application.WorkbenchAdvisor.eventLoopIdle(Wo rkbenchAdvisor.java:356)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2311)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2273)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:372)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:153)
at org.eclipse.rap.demo.DemoWorkbench.createUI(DemoWorkbench.ja va:24)
org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:212)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:109)
at java.lang.Thread.run(Thread.java:595)
is it a bug?How to fix it?
thanks a lot,
cheney
Re: Problem in Progress Bar [message #75619 is a reply to message #75545] |
Tue, 26 February 2008 16:42   |
Originally posted by: fappel.innoopract.com
seems as if the thread survives the session restart, which is in
principle nothing we can do about. There's no way to cancel a thread if
there's no build in check by the application code. So if a background
thread is associated with a session a robust implementation should check
whether the session has been expired and terminate itself in that case.
The demo doesn't have such a build in check.
On the other hand it seems as the background thread is still able to
call Display#asyncExcec or Display#syncExec even if the display has been
already disposed of. This should not be possible, since the problem
kills the proper execution of the UIThread of the newly initialzed
session. So from that point of view it's a bug in terms of robustness.
The background thread that tries to add the runnable into the new
session should retrieve the exception not the UIThread.
I filed a bug (#220467) using your problem description. Thx!
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Cheney Chen [mailto:cheney_chen@i-len.com]
Bereitgestellt: Dienstag, 26. Februar 2008 12:45
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Problem in Progress Bar
Betreff: Problem in Progress Bar
hi,
Steps to reproduce:
Bar is running(the percent of the task isn't complete),refresh the
Browser then relaunch the application.
Exception
information:
doStart
a:119)
dicator.java:100)
ifeCycle.java:369)
eCycle.java:183)
269)
or.java:356)
72)
Manager.java:92)
va:212)
thanks a lot,
cheney
Re: Problem in Progress Bar [message #75829 is a reply to message #75619] |
Wed, 27 February 2008 05:25  |
Thank you for your answer.
Frank Appel wrote:
As I know there have SessionStoreListener class in RAP,so we can do
something before the session is destroy.Then it is possible to destroy the
backgroud thread is associated with a session before the session is
destroy,or we need do this by myself?
> Ciao
> Frank
> hi,
> Steps to reproduce:
> Exception
> information:
> doStart
> at
> at
> a:119)
> at
> dicator.java:100)
> at
> at
> at
> at
> at
> at
> at
> ifeCycle.java:369)
> at
> eCycle.java:183)
> at
> 269)
> at
> or.java:356)
> at
> at
> 72)
> at
> at
> at
> Manager.java:92)
> at
> va:212)
> at
> thanks a lot,
> cheney
Current Time: Fri Jul 18 06:24:44 EDT 2025
Powered by FUDForum. Page generated in 1.01201 seconds
