Home » Archived » Test and Performance Tools Platform (TPTP) » Cannot open PerfmonAgent subnodes in AgentControl view
Cannot open PerfmonAgent subnodes in AgentControl view [message #75504] Thu, 29 June 2006 08:58 Go to next message
Originally posted by: martin.schuetz.vmasch.at
I'm trying to monitor Windows System Trace (Perfmon - RAC_v6-0-1-3) with
TPTP 4.0.1 (Eclipse 3.1.1 on Windows XP) - unfortunately without success.
After starting the PerfmonAgent.exe I can add the agent in the "Profile"
window and when I click "Start monitoring" the agent appears in the
AgentControl view. But I only can expand the "PerfmonAgent" node - no
subnodes (e.g. "Processor" as described at
http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. tptp.platform.doc.user/tasks/simple_t_launchingAgent.htm )
PerfmonAgent-console shows the following:
Using Resource DLL "sysperf.dll", Communications DLL "rac.dll"
Sending agent name from the collection DLL - PerfmonAgent
PerfmonAgent received agentname of PerfmonAgent
Setting the agent name is the transfer DLL to PerfmonAgent
Loading RAC libraries
Getting RAC functions
Initializing RAC bindings
Connecting to RAC - PerfmonAgent - 1151478506071
Starting RAC listener
Allocating message block
RAC Startup succesful
Allocating buffer
RAC Command 00000050
RAC Agent Controller available
No agent monitoring yet (freq:3000ms)
RAC Command 0000001A
Received an unrecognised RA_CUSTOM_COMMAND event,
name=var_string?HOST?localhost, value=var_string?HOST?localhost
name=var_string?PORT?10002, value=var_string?PORT?10002
RAC Command 00000017
RAC Agent Started Monitoring 0
Perfmon Datacollection:Collecting from host (null)
Received an unrecognised RA_CUSTOM_COMMAND event, name=updatetree?238?true,
value=updatetree?238?true
Received an unrecognised RA_CUSTOM_COMMAND event, name=updatetree?230?true,
value=updatetree?230?true
Anyone experienced the same problems?
What's going wrong?
Martin
Re: Cannot open PerfmonAgent subnodes in AgentControl view [message #75535 is a reply to message #75504] Thu, 29 June 2006 09:17 Go to previous messageGo to next message
Originally posted by: RGuschin.computel.ru
Same problem :(
> Allocating buffer
> What's going wrong?
> Martin
> From - Thu
Re: Cannot open PerfmonAgent subnodes in AgentControl view [message #75586 is a reply to message #75535] Thu, 29 June 2006 11:46 Go to previous messageGo to next message
Originally posted by: lars.nospam.org
Its been a while since I used 3.1.1 and TPTP 4.01, but here are some
suggestions:
1 The list of available topics can sometimes take time to appear! Wait
for a while....
2. The default severe name is localhost (defined in the Settings tab for
the Windows Perform) - perhaps this is not the case for you machine?
(for my company it is not)
/Lars
"Rodion Guschin" <RGuschin@computel.ru> skrev i meddelandet
news:e80jsk$r65$1@utils.eclipse.org...
> Same problem :(
>> Allocating buffer
>> name=updatetree?238?true, value=updatetree?238?true
>> name=updatetree?230?true, value=updatetree?230?true
>> What's going wrong?
>> Thanks,
>> Martin From - Thu
Re: Cannot open PerfmonAgent subnodes in AgentControl view [message #75756 is a reply to message #75586] Fri, 30 June 2006 02:19 Go to previous messageGo to next message
Now I've tried with Eclipse 3.2.0 and TPTP 4.2 ... all worked fine!
"Lars Ohl
Re: Cannot open PerfmonAgent subnodes in AgentControl view [message #75773 is a reply to message #75586] Fri, 30 June 2006 02:55 Go to previous messageGo to next message
Thanks :) changing host name works for me.
Another question - where can i see Perfmon logs like one Martin Schuetz
posted. I don`t have an idea where to look for.
Lars Ohlén wrote:
> suggestions:
> for a while....
> /Lars
>> Same problem :(
>>> Allocating buffer
>>> What's going wrong?
>>> Thanks,
>>> Martin From - Thu
Re: Cannot open PerfmonAgent subnodes in AgentControl view [message #75839 is a reply to message #75773] Fri, 30 June 2006 09:17 Go to previous messageGo to next message
Hi ,
You can see the Perform printouts if you manually start the PerfomAgent.exe
with the -v (for verbose) option.
/Lars
"Rodion Guschin" <RGuschin@computel.ru> wrote in message
news:e82ht8$rvb$1@utils.eclipse.org...
> Lars Ohl
Re: Cannot open PerfmonAgent subnodes in AgentControl view [message #75856 is a reply to message #75839] Fri, 30 June 2006 10:02 Go to previous messageGo to next message
Hi, thanks for answering :)
Manually? How?
Rodion
Lars Ohlén wrote:
> Hi ,
> /Lars
>> Lars Ohlén wrote:
>>> Hi,
>>> suggestions:
>>> for a while....
>>> for the Windows Perform) - perhaps this is not the case for you machine?
>>> /Lars
>>>> Same problem :(
>>>>> with TPTP 4.0.1 (Eclipse 3.1.1 on Windows XP) - unfortunately without
>>>>> success.
>>>>> "Profile" window and when I click "Start monitoring" the agent appears
>>>>> in the AgentControl view. But I only can expand the "PerfmonAgent"
>>>>> node - no subnodes (e.g. "Processor" as described at
>>>>> Allocating buffer
>>>>> What's going wrong?
>>>>> Thanks,
>>>>> Martin From - Thu
Re: Cannot open PerfmonAgent subnodes in AgentControl view [message #75873 is a reply to message #75856] Fri, 30 June 2006 10:32 Go to previous messageGo to next message
You can find PerfmonAgent.exe in the bin-directory of the
AgentController-package - I've downloaded V6.0.1.3 from
http://www-128.ibm.com/developerworks/autonomic/probdet1.htm l
Martin
>Manually? How?
>Rodion
Re: Cannot open PerfmonAgent subnodes in AgentControl view [message #75939 is a reply to message #75873] Fri, 30 June 2006 14:09 Go to previous message
Originally posted by: graymagi.gmail.com
I've already got Perfmoneagent :)
What i'm doing:
Start ACServer.exe.
Start PerfMonAgent.exe -v
Start eclipse, connect to localhost:10002, start monitoring, even can
see some information about my host, but still no logs in PerfmonAgent
window.... strange isn't it?
Rodion
> Martin
>> Manually? How?
>> Rodion
Previous Topic:Analysis rules problem
Next Topic:Does hyades work with Java 1.5 and RCP?
Current Time: Sun Jul 27 01:29:53 EDT 2025
Powered by FUDForum. Page generated in 0.05679 seconds
