Home » Archived » BIRT » Examples
Examples [message #75443] Mon, 19 September 2005 06:16 Go to next message
Hello Everyone,
Does anybody know where I can find examples of BIRT reports - as in
..rptdesign design files to see how to use BIRT's features?
Gerhard
Re: Examples [message #75476 is a reply to message #75443] Mon, 19 September 2005 09:51 Go to previous messageGo to next message
Gerhard,
Under the plugins\org.eclipse.birt.report.designer.ui_1.0.1\sampleRepo rts
directory, you should find several example reports.
Jason Weathersby
BIRT PMC
"Gerhard Wessels" <gerhard@eastmin.co.za> wrote in message
news:MPG.1d98bc813ebae091989683@192.168.1.149...
> Hello Everyone,
> Gerhard
Re: Examples [message #75814 is a reply to message #75476] Tue, 20 September 2005 08:15 Go to previous messageGo to next message
Jason,
Thank you.
Where can I find the databases to which the reports connect?
I have set up the "classicmodels" db on mysql and it works, but I see
there are SQL Server database connections as well in some of the reports
- and maybe others to other dbs also, I didn't check every report.
Thanks!
In article <dgmfo3$aqp$1@news.eclipse.org>, jweathersby@actuate.com
says...
> Gerhard,
> Jason Weathersby
> BIRT PMC
> > Hello Everyone,
> > Thanks,
> > Gerhard
Re: Examples [message #75882 is a reply to message #75814] Tue, 20 September 2005 10:06 Go to previous message
Gerhard,
I thought all of them used classicmodels only. We are in the process of
converting these to put on the website. I will check to see if the
databases are different. Even if they are on SQL Server It should still be
using the same schema.
Jason Weathersby
BIRT PMC
news:MPG.1d9a29c1b9e79402989684@192.168.1.149...
> Jason,
> Thank you.
> Thanks!
> says...
>> Gerhard,
>> Jason Weathersby
>> BIRT PMC
>> > Hello Everyone,
>> > Thanks,
>> > Gerhard
Previous Topic:birt - Apalette is not available.
Next Topic:How to use a value from one of the
Current Time: Sat Nov 08 22:35:10 EST 2025
Powered by FUDForum. Page generated in 0.03323 seconds
