Home » Archived » M2M (model-to-model transformation) » [ATL] Re: AMW Model Handler (mwplugins-20070330) doesn't appear in RSA7(Eclipse3.2)
[ATL] Re: AMW Model Handler (mwplugins-20070330) doesn't appear in RSA7(Eclipse3.2) [message #75439] Wed, 27 February 2008 07:46 Go to next message
Originally posted by: mddfabro.ilog.fr
check the error log to see if there are any error during the load. This
may help to identify your issue.
Marcos.
PS.: I am copying the m2m newsgroup as well, since you did almost the
same question there.
Jinhui wrote:
> Hi everyone,
> I have the following problem:
> I'm using RSA7(based on Eclipse3.2), and I have installed ATL(2007 Feb 16).
> Now after I downloaded the AMW (version mwplugins-20070330), and extract
> it to the RSA plugin directory, the AMW Model Handler doesn't appear as
> a Model Handler in the Run Configuration.
> Does anyone has this problem too? Btw, I'm having the same problem with
> the "UML2 Model Handler" from ATL.
> regards.
> Jinhui
Re: [ATL] Re: AMW Model Handler (mwplugins-20070330) doesn't appear in RSA7(Ecli [message #75458 is a reply to message #75439] Wed, 27 February 2008 09:56 Go to previous messageGo to next message
Originally posted by: zhuj.in.tum.de
I now managed to configure them all to work.
the combinations is:
* RSA7
* ATL version 2.0RC2
* AMW version "Development build Build date October 15th, 2007"
thanks for your reply anyway.
Jinhui
> Hello,
> Marcos.
Re: [ATL] Re: AMW Model Handler (mwplugins-20070330) doesn't appear in RSA7(Ecli [message #75474 is a reply to message #75439] Wed, 27 February 2008 09:59 Go to previous message
* RSA7
Jinhui
Previous Topic:[ATL] newbie question: what is the right ATL version to work with RSA7?
Next Topic:[ATL] Model Handler MDR
Current Time: Mon Sep 01 08:00:19 EDT 2025
Powered by FUDForum. Page generated in 0.04286 seconds
