[ATL] Re: AMW Model Handler (mwplugins-20070330) doesn't appear in RSA7(Eclipse3.2) [message #75439] |
Wed, 27 February 2008 07:46  |
Originally posted by: mddfabro.ilog.fr
check the error log to see if there are any error during the load. This
may help to identify your issue.
Marcos.
PS.: I am copying the m2m newsgroup as well, since you did almost the
same question there.
Jinhui wrote:
> Hi everyone,
> I have the following problem:
> I'm using RSA7(based on Eclipse3.2), and I have installed ATL(2007 Feb 16).
> Now after I downloaded the AMW (version mwplugins-20070330), and extract
> it to the RSA plugin directory, the AMW Model Handler doesn't appear as
> a Model Handler in the Run Configuration.
> Does anyone has this problem too? Btw, I'm having the same problem with
> the "UML2 Model Handler" from ATL.
> regards.
> Jinhui
FUDForum. Page generated in 0.04474 seconds
