Home » Language IDEs » Java Development Tools (JDT) » Refactor/rename does not bring up any dialog box (?)
Refactor/rename does not bring up any dialog box (?) [message #75429] Mon, 14 July 2003 06:15 Go to next message
Originally posted by: g.olgeni.colby.it
Hi there,
Looking for more help...
I was poking around refactoring in the freebsd eclipse port (2.1.1), and
noticed that Refactor/Rename does not bring up any dialog box when I
select it over any source code identifier. No error message shows up on
eclipse's stdout.
If I bring it up on a comment it will properly complain about needing to
choose an identifier, so the option is actually calling some code :-)
Doing the same on 2.1.1 (win32 binary release) makes the rename dialog
appear (and I'm using the same sample source code).
Every other refactoring option seems to work just fine... The same
happened on 2.1... what could it be?
jimmy
Re: Refactor/rename does not bring up any dialog box (?) [message #75446 is a reply to message #75429] Mon, 14 July 2003 06:19 Go to previous messageGo to next message
Originally posted by: adam_kiezun.ch.ibm.remove.com
did you build eclipse from source yourself?
a.
eclipse.org
Re: Refactor/rename does not bring up any dialog box (?) [message #75462 is a reply to message #75446] Mon, 14 July 2003 06:25 Go to previous messageGo to next message
Yes, the port first builds the C parts and then uses ant to compile the
java stuff as usual.
jimmy
Re: Refactor/rename does not bring up any dialog box (?) [message #75478 is a reply to message #75462] Mon, 14 July 2003 06:37 Go to previous messageGo to next message
known issue
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=37846
a.
eclipse.org
Re: Refactor/rename does not bring up any dialog box (?) [message #75622 is a reply to message #75478] Mon, 14 July 2003 10:40 Go to previous messageGo to next message
I tried to use target="1.1" in every javac task, but nothing changed...
is there an "official" workaround for this? (i.e. can I borrow a patch
from CVS?)
Or should every method in SelectionDispatchAction be made public?
jimmy
Re: Refactor/rename does not bring up any dialog box (?) [message #75639 is a reply to message #75622] Mon, 14 July 2003 10:42 Go to previous messageGo to next message
the problem is that that'd be not enough:
- every protected method in SelectionDispatchAction and all of its subclasses would have to be made public
you can try that and tell us if it worked
a.
eclipse.org
Re: Refactor/rename does not bring up any dialog box (?) [message #75655 is a reply to message #75639] Mon, 14 July 2003 11:45 Go to previous messageGo to next message
Originally posted by: muelleimer.usenet.katzien.de
Hallo!
* Adam Kiezun <adam_kiezun@ch.ibm.remove.com> wrote:
[target="1.1" not working]
I found that out too :(
I will add my patch to the BTS. I've patched this via eclipse and it
seems to work.
Jan
Re: Refactor/rename does not bring up any dialog box (?) [message #75774 is a reply to message #75639] Mon, 14 July 2003 16:43 Go to previous message
It worked! I did some brutal refactoring from the Makefile with xargs,
grep and sed :o)
jimmy
Previous Topic:Console activation in custom perspective
Next Topic:Re: CVS Graph plugin for Eclipse available
Current Time: Mon Sep 01 00:29:44 EDT 2025
Powered by FUDForum. Page generated in 0.05046 seconds
