Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo]Multiple inheritance with multi-valued EReferences in second inherited class fails
[Teneo]Multiple inheritance with multi-valued EReferences in second inherited class fails [message #75420] Wed, 14 March 2007 08:26 Go to next message
Multiple inheritance works fine except when the second (or after) inherited
class has a multi-valued EReference.
I have attached a bundle that you can directly import into Eclipse.
I have removed hibernate and other third party JARs to keep the attachment
small so it will not run until you put all the jars in the lib directory. I
can send you the exact versions if necessary.
It will add a launcher called InheritanceTests.
These tests will fail with a "Could not execute JDBC batch update" exception
which I have included at the bottom of this message.
In this model, a model object called SomeResource extends SomeBaseClass and
SomeOtherBaseClass (in that order). SomeOtherBaseClass has a multi-valued
EReference property called "nameValuePairs" which is an EList of
NameValuePair objects. If you reverse the order of inheritance or remove the
nameValuePairs property then the tests will pass fine.
This test uses Teneo 0.8.0 with HSQLDB. The test suites will dynamically
remove the DB if it exists and regenerate it before each test.
If this is determined to be a bug, it would be great if this fix could also
be applied to a Teneo 0.7.5 release as well.
Thanks for all the work you put into this effort - IMO, it really makes EMF
viable.
-mike
org.hibernate.exception.GenericJDBCException: Could not execute JDBC batch
update
org.hibernate.exception.SQLStateConverter.handledNonSpecific Exception(SQLStateConverter.java:103)
org.hibernate.exception.SQLStateConverter.convert(SQLStateCo nverter.java:91)
org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExce ptionHelper.java:43)
at org.hibernate.jdbc.AbstractBatcher.executeBatch(AbstractBatc her.java:249)
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue. java:235)
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue. java:143)
org.hibernate.event.def.AbstractFlushingEventListener.perfor mExecutions(AbstractFlushingEventListener.java:298)
org.hibernate.event.def.DefaultFlushEventListener.onFlush(De faultFlushEventListener.java:27)
at org.hibernate.impl.SessionImpl.flush(SessionImpl.java:1000)
org.eclipse.emf.teneo.hibernate.resource.HibernateResource.s aveResource(HibernateResource.java:244)
at org.eclipse.emf.teneo.resource.StoreResource.save(StoreResou rce.java:365)
test.teneo.inheritance.InheritanceTests.testSavingAuthorizab les(InheritanceTests.java:96)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:128)
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
Caused by: java.sql.BatchUpdateException: failed batch
at org.hsqldb.jdbc.jdbcStatement.executeBatch(Unknown Source)
at org.hsqldb.jdbc.jdbcPreparedStatement.executeBatch(Unknown Source)
org.hibernate.jdbc.BatchingBatcher.doExecuteBatch(BatchingBa tcher.java:48)
at org.hibernate.jdbc.AbstractBatcher.executeBatch(AbstractBatc her.java:242)
.... 26 more
Re: [Teneo]Multiple inheritance with multi-valued EReferences in second inherited class fails [message #75592 is a reply to message #75420] Wed, 14 March 2007 11:23 Go to previous messageGo to next message
Hi Mike,
Thanks for providing a testcase. I am kind of busy so it will maybe be a few days (friday or so)
before I can take a look at it.
If it is a fixable bug then I'll provide bugfixes for both the 0.7.5 and 0.8.0 release.
gr. Martin
> viable.
> -mike
> update
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> .... 26 more
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo]Multiple inheritance with multi-valued EReferences in second inherited class fails [message #75990 is a reply to message #75420] Sun, 18 March 2007 18:09 Go to previous messageGo to next message
Mike,
I tested it with mysql and the same error occurs. The cause is the following (assuming joined table
inheritance). As a result of the mapping teneo/hibernate will create 4 tables:
namevaluepair
somebaseclass
someotherbaseclass
someresource
someresource has a foreign key to somebaseclass (its parent eclass table).
The namevaluepair table will have a column for the namevalue pair feature of someotherbaseclass.
This joincolumn has the name: someotherbaseclass_namevaluepairs_e_id.
However because someresource also inherits this feature two foreign keys are created on this one
column, one fk to someresource and one to someotherbaseclass. This happens because the mapping of
namevaluepairs in someresource uses the same joincolumn. The two fk's on one column always result in
a fk constraint violation because when a record is created in someresource, the id of someresource
is placed in someotherbaseclass_namevaluepairs_e_id resulting in a fk violation to
someotherbaseclass (as there is no record in that table).
So to solve this the inherited namevaluepairs feature of someresource needs to use a different
joincolumn.
Can you enter a bugzilla for this? Then I can implement a solution in 0.7.5/0.8.0. Bugzillas are
required for creating the release notes.
When the bugzilla is entered I will create a bugfix for this. The bugfix will automatically rename
the jointable/column for inherited efeatures.
gr. Martin
> viable.
> -mike
> update
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> .... 26 more
The Netherlands
Re: [Teneo]Multiple inheritance with multi-valued EReferences in second inherited class fails [message #76098 is a reply to message #75990] Tue, 20 March 2007 20:32 Go to previous message
Bugzilla number 178471.
-mike
"Martin Taal" <mtaal@elver.org> wrote in message
news:etkdbb$8eu$1@utils.eclipse.org...
> Mike,
> following (assuming joined table inheritance). As a result of the mapping
> namevaluepair
> somebaseclass
> someotherbaseclass
> someresource
> of someotherbaseclass. This joincolumn has the name:
> are created on this one column, one fk to someresource and one to
> someotherbaseclass. This happens because the mapping of namevaluepairs in
> result in a fk constraint violation because when a record is created in
> someresource, the id of someresource is placed in
> needs to use a different joincolumn.
> 0.7.5/0.8.0. Bugzillas are required for creating the release notes.
> will automatically rename the jointable/column for inherited efeatures.
> gr. Martin
>> inherited class has a multi-valued EReference.
>> attachment small so it will not run until you put all the jars in the lib
>> directory. I can send you the exact versions if necessary.
>> exception which I have included at the bottom of this message.
>> and SomeOtherBaseClass (in that order). SomeOtherBaseClass has a
>> multi-valued EReference property called "nameValuePairs" which is an
>> EList of NameValuePair objects. If you reverse the order of inheritance
>> or remove the nameValuePairs property then the tests will pass fine.
>> also be applied to a Teneo 0.7.5 release as well.
>> EMF viable.
>> -mike
>> batch update
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> .... 26 more
> The Netherlands
Re: [Teneo]Multiple inheritance with multi-valued EReferences in second inherited class fails [message #603643 is a reply to message #75420] Wed, 14 March 2007 11:23 Go to previous message
Hi Mike,
gr. Martin
> viable.
> -mike
> update
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> .... 26 more
The Netherlands
Re: [Teneo]Multiple inheritance with multi-valued EReferences in second inherited class fails [message #603718 is a reply to message #75420] Sun, 18 March 2007 18:09 Go to previous message
Mike,
namevaluepair
somebaseclass
someotherbaseclass
someresource
joincolumn.
gr. Martin
> viable.
> -mike
> update
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> .... 26 more
The Netherlands
Re: [Teneo]Multiple inheritance with multi-valued EReferences in second inherited class fails [message #603748 is a reply to message #75990] Tue, 20 March 2007 20:32 Go to previous message
-mike
> Mike,
> namevaluepair
> somebaseclass
> someotherbaseclass
> someresource
> gr. Martin
>> EMF viable.
>> -mike
>> batch update
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> .... 26 more
> The Netherlands
Previous Topic:Duplicate properties appearing in subclass.
Next Topic:New to JET can't access xsi:type value
Current Time: Sat Aug 30 14:37:13 EDT 2025
Powered by FUDForum. Page generated in 0.04570 seconds
