Home » Eclipse Projects » Eclipse Platform » [Views] Communication between views.
[Views] Communication between views. [message #75411] Mon, 16 June 2003 09:16 Go to next message
I am having couple of views with treeViewers. I want to pass the selection
of treeviewer in one view to the other view. Anybody have any idea abt it.
(I want something like IEditorInput).
Currently I am using showView() API to open the secong view.
Dinesh
Re: [Views] Communication between views. [message #75499 is a reply to message #75411] Mon, 16 June 2003 10:04 Go to previous messageGo to next message
Hi.
A few ways spring to mind.
1 - Using singleton static getInstance() methods in the views.
By statically referencing the views, like this:
View1{
method(){
View2.getInstance().newSelection(selection);
View2{
public static View2 getInstance(){
return instance;
public void newSelection(...){
// do stuff
2 - Using ViewPart.setSelectionProvider(treeviewer)
register selection provider in one view (can be a tree viewer):
this.getSite().setSelectionProvider(theTreeViewer);
and register selectionchangedlistener in some other view:
this.getSite().getSelectionProvider().addSelectionChangedLis tener(aSelection
ChangedListener);
Good luck,
Emil
"Dinesh Varadharajan" <dvaradharajan@selectica.com> skrev i meddelandet
news:bckfud$3sj$1@rogue.oti.com...
> Dinesh
Re: [Views] Communication between views. [message #75614 is a reply to message #75499] Mon, 16 June 2003 11:20 Go to previous messageGo to next message
Originally posted by: richkulp.NOSPAM.us.ibm.com
I don't recommend (1) because you can have more the one workbench page
open at a time, and each could have an instance of your view. So there
is no one static instance.
Rich
Re: [Views] Communication between views. [message #76010 is a reply to message #75614] Tue, 17 June 2003 02:51 Go to previous messageGo to next message
"Richard L. Kulp" <richkulp@NOSPAM.us.ibm.com> schrieb im Newsbeitrag
news:bcknb6$aj7$3@rogue.oti.com...
Right. What I sometimes do is to provide a domain for every window/worbench
page
and allow to also listen up to a global change which changes depending on
the local changes.
Registering the domain is just easy by using a singelton domain context
manager and map the domains depending on the window/workbench page.
Works well here... .
Bye
Martin (Kersten)
Worked >> [Views] Communication between views. [message #76232 is a reply to message #75499] Tue, 17 June 2003 08:23 Go to previous message
Thanks a lot, The second option worked fine for me. I didn't tested with the
first one.
Dinesh
"Emil Einarsson" <emil.einarsson@solme.se> wrote in message
news:bckir3$6qn$1@rogue.oti.com...
> Hi.
> View1{
> method(){
> View2{
> return instance;
> // do stuff
> ChangedListener);
> Good luck,
> Emil
> > Hi,
selection
it.
> > Thanks,
> > Dinesh
Previous Topic:classpathVariableInitializer doesn't seem to work under Eclipse 2.01
Next Topic:undo / redo
Current Time: Fri Jul 25 09:43:20 EDT 2025
Powered by FUDForum. Page generated in 0.03379 seconds
