problems resolving plugin dependency org.eclipse.gef [message #75404] |
Thu, 10 April 2003 19:39  |
Originally posted by: aekapon.comcast.net
i have tried everything to get this hello gef example to work. I think that
i have gef installed correctly, but for some reason when i try to run the
hello gef files, i get an error saying
"Connot resolve plug-in dependency: org.eclipse.gef." and..
"Unkown extension point: org.eclipse.ui.editors"
I know its there, because i get the logic example to work and the xml has
the same entries for both the logic diagram and the hellogefs, has anyone
encountered a similar problem or know what to do to fix it?
thanks, Niall Little
Re: problems resolving plugin dependency org.eclipse.gef [message #75454 is a reply to message #75404] |
Fri, 11 April 2003 01:27   |
forgot to mention, i am running the 2.1 versions of eclipse and gef. I went
to the plugin details under help->about and the gef is showing up as
org.eclipse.gef, so i cant think of any reason the sample cant resolve the
plugin, if anyone could PLEASE!!! help me with this i would be so greatful,
Niall Little
"Niall Little" <aekapon@comcast.net> wrote in message
news:b74use$r2g$1@rogue.oti.com...
that
Re: problems resolving plugin dependency org.eclipse.gef [message #75574 is a reply to message #75454] |
Sun, 13 April 2003 18:25  |
news:b75j8m$774$1@rogue.oti.com...
went
> plugin,
When you run a second platform for testing, that platform includes only the
plugins it's told to include. Look in the Eclipse help under "PDE Guide >
Configuring PDE" and make sure org.eclipse.gef and org.eclipse.ui.editors
are both checked.
....Richard
FUDForum. Page generated in 0.03816 seconds
