Home » Archived » Test and Performance Tools Platform (TPTP) » Analysis rules problem
Analysis rules problem [message #75351] Wed, 28 June 2006 01:31 Go to next message
Originally posted by: berndt.johansson.gmail.com
I have installed the runtime package for all tptp parts according to the
installation guide and wanted to try out the code analysis part. However,
I have encountered a problem with the Analysis configurations. For some reason,
the Analysis Domains and Rule tab is empty. And I guess, as a consequence
of that, performing an analysis will generate a launch error.
Is there anyone that have experienced the same problems?
/Berndt
Re: Analysis rules problem [message #75402 is a reply to message #75351] Wed, 28 June 2006 07:00 Go to previous messageGo to next message
Which version are you trying to use? If it is 4.1 I don't believe there were
any rules shipped with the analysis framework. In 4.2 there are 71 rules
for Java and approximately 25 for C++ (added as a separate plugin).
"Berndt Johansson" <berndt.johansson@gmail.com> wrote in message
news:15066477245f8c868a4731aef68@news.eclipse.org...
> Hi
reason,
> /Berndt
Re: Analysis rules problem [message #75704 is a reply to message #75402] Thu, 29 June 2006 15:18 Go to previous messageGo to next message
Hello Steve,
I am using the 4.1.0.1 release and I did not realize that I have to all the
rules manually.
I downloaded the 4.2 release today and got a bit further. The domain tab
contains one entry for "Code Review for Java", but still no rules. Do you
know of a location for getting a set of rules plugin or any guideline for
creating these rules?
Really apreciate any help on this, thank you.
/Berndt
> there were any rules shipped with the analysis framework. In 4.2
> there are 71 rules for Java and approximately 25 for C++ (added as a
> separate plugin).
>> Hi
>> the installation guide and wanted to try out the code analysis part.
>> However, I have encountered a problem with the Analysis
> reason,
>> consequence of that, performing an analysis will generate a launch
>> error.
>> /Berndt
Re: Analysis rules problem [message #75806 is a reply to message #75704] Fri, 30 June 2006 05:44 Go to previous messageGo to next message
Originally posted by: s_gutz.yahoo.com
Can you not expand "Code Review for Java" and see several categories and 71
rule?
Look in you plugins directory to ensure that you have a plugin named
org.eclipse.tptp.platform.analysis.codereview.java.rules (probably a jar
file).
On 6/29/06 3:18 PM, in article 1506647724db8c869e116a592a4@news.eclipse.org,
"Berndt Johansson" <berndt.johansson@gmail.com> wrote:
> Hello Steve,
> rules manually.
> /Berndt
>> separate plugin).
>>> Hi
>> reason,
>>> error.
>>> /Berndt
Re: Analysis rules problem [message #75822 is a reply to message #75806] Fri, 30 June 2006 05:53 Go to previous message
Actually you shouldn't even have a "Domains" tab anymore. In 4.2 it has
been renamed "Rules".
I just did a test where I installed base Eclipse 3.2 and TPTP 4.2 build
TPTP-4.2.0-200606190100 and it worked as expected. So the build seems to be
fine.
On 6/30/06 5:44 AM, in article C0CA6ADB.1EB2%s_gutz@yahoo.com, "Steve Gutz"
> rule?
> file).
>> Hello Steve,
>> rules manually.
>> /Berndt
>>> separate plugin).
>>>> Hi
>>> reason,
>>>> error.
>>>> /Berndt
Previous Topic:TPTP setup errors asking for BIRT
Next Topic:Cannot open PerfmonAgent subnodes in AgentControl view
Current Time: Sun Aug 31 02:20:15 EDT 2025
Powered by FUDForum. Page generated in 0.15352 seconds
