Composite Figure [message #75290] |
Tue, 07 November 2006 09:06  |
Originally posted by: snej_NO-SPAM_.esuark.de
Hi There,
i need a little help. I want to have a figure wich the user could select
from the tools palette, but which creates 2 figures in the diagramm.
For example a checkbox:
* one figure for the checked (or unchecked) button
* one figure for the label
I solved the problem right now with one figure, but the label and the
checkbox should be moveable, so that you could move the label before or
over the checkbox. I don't know if i discribed it enought what my
problem is, so if there is any question ...
regards
jens
Re: Composite Figure [message #83010 is a reply to message #82953] |
Tue, 05 December 2006 08:35  |
Originally posted by: 5d5.mail.ru
Look at the generated <ModelID>ExtNodeLabelEditPart - label position is
calculated there.
Jens Krause wrote:
> Dmitry Stadnik wrote:
>> You could try to set node figure as checkbox and define label as
>> external label - it will be possible to position it anywhere around
>> the checkbox.
> Well, this one solution, but then the label is created anywhere. If
> there would be a possibility to set the position relative to the
> checkbox figure, but i haven't found one.
> jens
FUDForum. Page generated in 0.03618 seconds
