[ATL] Basic Example -- Tree2List : Bug with "uses Lib4MMTree" [message #75187] |
Thu, 21 February 2008 04:19 |
Originally posted by: zhuj.in.tum.de
Hi everyone,
I'm having the following Bug with ATL Basic Example "Tree2List":
* if I use the statement "uses Lib4MMTree;", then the engine just checks
the first inner tree node(either "another node" OR "last node"), after the
call to "rt.isTreeNodeRoot()", it just terminated. This is of course
wrong, the engine should check all the three nodes in turn.
* if I copy the three helpers into "Tree2List.atl", and remove the "uses
Lib4MMTree", then the engine correctly checks the three nodes in turn.
What's the reason for this behavior?
btw, I'm using ATL Version (Feb 16 2007) with RSA7.0.
FUDForum. Page generated in 0.03357 seconds
