Home » Eclipse Projects » Eclipse Platform » debugging problem - absent line numbers
debugging problem - absent line numbers [message #601] Mon, 21 April 2003 10:40 Go to next message
I am having trouble debugging only one of my projects. I'm pretty sure it's
setup exactly like the other ones I have, but this is the only one that I
cannot debug.
When I try to hit the breakpoint, i get the error msg "Attempting to install
a breakpoint in the type package.name.goes.here that has no line number
attributes. THe breakpoint cannot be installed. Class files must be
generated with the line number attributes.
Reason: Absent Line Number Information
I double checked the compiler settings and the Compile with line numbers
option is set to true.
any ideas out there? is this a bug with eclipse?
thanks.
Re: debugging problem - absent line numbers [message #651 is a reply to message #601] Mon, 21 April 2003 11:54 Go to previous message
Originally posted by: Olivier_Thomann.oti.com
On Mon, 21 Apr 2003 10:40:02 -0400, "ttoyohara"
Are you changing the .class file once generated?
If not, please open a bug report against JDT/Core with steps to
reproduce and attach the source file and the corresponding .class file
for the file on which you are trying to set a breakpoint. The .class
file is located in the output folder of the source folder in which
your source file is defined.
Olivier
Previous Topic:create a new button
Next Topic:Dual key keybinding problem
Current Time: Tue Jul 22 14:37:22 EDT 2025
Powered by FUDForum. Page generated in 0.03145 seconds
