Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Null Pointer Exception in HbDataStore ComputeReferers
[Teneo] Null Pointer Exception in HbDataStore ComputeReferers [message #75126] Mon, 12 March 2007 08:56 Go to next message
I have been attempting to intialize an HB Datastore however I am hitting a Null Pointer
Exception in the computeReferers method of the HbDataStore. The full stack trace is:
at org.eclipse.emf.teneo.hibernate.HbDataStore.computeReferers( HbDataStore.java:742)
at org.eclipse.emf.teneo.hibernate.HbDataStore.initialize(HbDat aStore.java:163)
org.sdmx.registry.persistence.TestHibernateSessionManager.te stTeneoPersistence(TestHibernateSessionManager.java:471)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at com.intellij.rt.execution.junit2.JUnitStarter.main(JUnitStar ter.java:32)
at com.intellij.rt.execution.application.AppMain.main(AppMain.j ava:90)
Setup: Teneo 0.75, EMF 2.2, Hiberate 3.2, Java 1.5
Other Info:
Within my setup I am using a hibernate mapping file which I generated with Teneo manually and force
its use through the USE_MAPPING_FILE persistence option.
From tracing through the code it would appear that it is falling over on this line below when it
attempts to get the 'element' from the property value and it is null. The property in question is an
org.hibernate.mapping.List.
throw new HbMapperException("Type "+ ((Collection)prop.getValue()).getElement().getClass().getNam e()
+ " not supported");
regards
Duncan
Re: [Teneo] Null Pointer Exception in HbDataStore ComputeReferers [message #75144 is a reply to message #75126] Mon, 12 March 2007 09:40 Go to previous messageGo to next message
Can you see which efeature it is trying to report there (the name of the property is the same as the
name of the efeature)?
And is there anything special with this efeature?
gr. Martin
Duncan ALexander wrote:
> stack trace is:
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> Other Info:
> on this line below when it attempts to get the 'element' from the
> regards
> Duncan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Null Pointer Exception in HbDataStore ComputeReferers [message #75161 is a reply to message #75144] Mon, 12 March 2007 09:57 Go to previous messageGo to next message
It looks its an org.hibernate.mapping.List(ref.IdentifierComponent.PartialTa rgetIdentifier).
From looking at my model, it may be that there is a slightly unmanageable relationship here
although Im not sure how to test if that is true.
What is this method doing, is it tracing through all the potential references between the classes ?
Duncan
> property is the same as the name of the efeature)?
> gr. Martin
>> stack trace is:
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> Other Info:
>> regards
>> Duncan
Re: [Teneo] Null Pointer Exception in HbDataStore ComputeReferers [message #75177 is a reply to message #75161] Mon, 12 March 2007 10:07 Go to previous messageGo to next message
The ecore for the Identifier component and its related PartialTargetIdentifier feature looks like:
<eClassifiers xsi:type="ecore:EClass" name="PartialTargetIdentifier"
eSuperTypes="base.ecore#//ComponentList">
<eStructuralFeatures xsi:type="ecore:EReference" name="MetadataStructure" lowerBound="1"
eType="#//MetadataStructure" transient="true"
eOpposite="#//MetadataStructure/PartialTargetIdentifier"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="IdentifierComponent" lowerBound="1"
upperBound="-1" eType="#//IdentifierComponent"
eOpposite="#//IdentifierComponent/PartialTargetIdentifier"/ >
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="IdentifierComponent"
eSuperTypes="base.ecore#//Component">
<eStructuralFeatures xsi:type="ecore:EReference" name="FullTargetIdentifier" lowerBound="1"
eType="#//FullTargetIdentifier" transient="true"
eOpposite="#//FullTargetIdentifier/IdentifierComponent"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="PartialTargetIdentifier"
upperBound="-1" eType="#//PartialTargetIdentifier"
eOpposite="#//PartialTargetIdentifier/IdentifierComponent"/ >
</eClassifiers>
> It looks its an
> unmanageable relationship here although Im not sure how to test if that
> is true.
> Duncan
>> the property is the same as the name of the efeature)?
>> gr. Martin
>>> Hi,
>>> stack trace is:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Other Info:
>>> over on this line below when it attempts to get the 'element' from
>>> regards
>>> Duncan
Re: [Teneo] Null Pointer Exception in HbDataStore ComputeReferers [message #75194 is a reply to message #75177] Mon, 12 March 2007 10:44 Go to previous messageGo to next message
Are you initializing the hbdatastore with the same properties (suc as qualify entity names) as used
for generating the hbm.xml?
A few lines higher in hbdatastore you can see these lines:
final Property prop = (Property) propIt.next();
EClass eClass;
try{
eClass = getPersistenceOptions().getEClassNameStrategy().toEClass(pc. getEntityName(), getEPackages());
} catch (IllegalArgumentException e) {
// ignoring exception on purpose
eClass = null;
final EStructuralFeature ef = eClass == null ? null : StoreUtil.getEStructuralFeature(eClass,
prop.getName());
apparently eClass and/or ef is null. Can you check which or why? This can be related to the fact
that maybe your hibernate.hbm.xml was generated using qualify entity names, while you run the
hbdatastore while not using these options (or the other way around).
This part of the code computes the referers. The hbdatastore offers a (fairly unknown) method which
allows you to retrieve all the referers to a certain object. The computereferers method computes
which other types can refer to a certain type and pre-creates all the queries.
gr. Martin
> </eClassifiers>
> </eClassifiers>
>> It looks its an
>> that is true.
>> Duncan
>>> gr. Martin
>>>> Hi,
>>>> stack trace is:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Other Info:
>>>> regards
>>>> Duncan
The Netherlands
Re: [Teneo] Null Pointer Exception in HbDataStore ComputeReferers [message #75211 is a reply to message #75194] Mon, 12 March 2007 11:09 Go to previous message
Aha,
yes thats exactly what I was doing. I removed the entry for QUALIFY_ENTITY_NAME from the
persistence properties when I was creating the datastore as I thought it could have no effect at
this stage.
From tracing the code it was the eClass which was NULL.
I've now put the QUALIFY_ENTITY_NAME entry into the properties when creating the store and it has
created the Database. Excellent!!!
Have just spotted another error but Ill start another thread, this is a huge jump forward.
Thanks again Martin.
Duncan
> qualify entity names) as used for generating the hbm.xml?
> EClass eClass;
> try{
> eClass =
> getEPackages());
> eClass = null;
> StoreUtil.getEStructuralFeature(eClass, prop.getName());
> can be related to the fact that maybe your hibernate.hbm.xml was
> generated using qualify entity names, while you run the hbdatastore
> (fairly unknown) method which allows you to retrieve all the referers to
> a certain object. The computereferers method computes which other types
> gr. Martin
>> </eClassifiers>
>> </eClassifiers>
>>> It looks its an
>>> that is true.
>>> Duncan
>>>> gr. Martin
>>>>> Hi,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Other Info:
>>>>> regards
>>>>> Duncan
Re: [Teneo] Null Pointer Exception in HbDataStore ComputeReferers [message #603511 is a reply to message #75126] Mon, 12 March 2007 09:40 Go to previous message
gr. Martin
> stack trace is:
> at
> at
> at
> at
> at
> at
> at
> at
> Other Info:
> regards
> Duncan
The Netherlands
Re: [Teneo] Null Pointer Exception in HbDataStore ComputeReferers [message #603517 is a reply to message #75144] Mon, 12 March 2007 09:57 Go to previous message
Duncan
> gr. Martin
>> stack trace is:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Other Info:
>> regards
>> Duncan
Re: [Teneo] Null Pointer Exception in HbDataStore ComputeReferers [message #603523 is a reply to message #75161] Mon, 12 March 2007 10:07 Go to previous message
</eClassifiers>
</eClassifiers>
> It looks its an
> is true.
> Duncan
>> gr. Martin
>>> Hi,
>>> stack trace is:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Other Info:
>>> regards
>>> Duncan
Re: [Teneo] Null Pointer Exception in HbDataStore ComputeReferers [message #603527 is a reply to message #75177] Mon, 12 March 2007 10:44 Go to previous message
EClass eClass;
try{
eClass = null;
prop.getName());
gr. Martin
> </eClassifiers>
> </eClassifiers>
>> It looks its an
>> that is true.
>> Duncan
>>> gr. Martin
>>>> Hi,
>>>> stack trace is:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Other Info:
>>>> regards
>>>> Duncan
The Netherlands
Re: [Teneo] Null Pointer Exception in HbDataStore ComputeReferers [message #603531 is a reply to message #75194] Mon, 12 March 2007 11:09 Go to previous message
Aha,
this stage.
Duncan
> EClass eClass;
> try{
> eClass =
> getEPackages());
> eClass = null;
> gr. Martin
>> </eClassifiers>
>> </eClassifiers>
>>> It looks its an
>>> that is true.
>>> Duncan
>>>> gr. Martin
>>>>> Hi,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Other Info:
>>>>> regards
>>>>> Duncan
Previous Topic:[Teneo] Null Pointer Exception in HbDataStore ComputeReferers
Next Topic:[Teneo]: Hibernate fails to add index and create table.
Current Time: Sun Jul 27 12:38:21 EDT 2025
Powered by FUDForum. Page generated in 0.05402 seconds
