Home » Archived » BIRT » subreports bound to calculated columns
subreports bound to calculated columns [message #75118] Fri, 16 September 2005 14:48 Go to next message
Originally posted by: jalexander.ici.org
Just wanted to see if/how it's possible to build a subreport with a
parameter tied to a calculated column, tried it a couple different ways with
no success. Got around my earlier problem, thanks, Jason
Re: subreports bound to calculated columns [message #75186 is a reply to message #75118] Fri, 16 September 2005 15:49 Go to previous message
Can you explain a little more.
Do you want the sub report to call a query using the calculated column from
the outer report?
Jason Weathersby
BIRT PMC
"jimbus" <jalexander@ici.org> wrote in message
news:dgf42d$apl$1@news.eclipse.org...
> with
Previous Topic:Review BIRT 2.0 - BPS 10 Library feature
Next Topic:HTML/PDF does not show up
Current Time: Sat Aug 30 12:56:09 EDT 2025
Powered by FUDForum. Page generated in 0.07172 seconds
