Home » Language IDEs » Java Development Tools (JDT) » Has anyone gotten Ant to work under Eclipse?
Has anyone gotten Ant to work under Eclipse? [message #74927] Fri, 11 July 2003 16:30 Go to next message
Originally posted by: wilco909.hotmail.com
Vanilla configuration: Windows 2000, Eclipse 2.1.1, Sun JDK 1.4.2, Ant
1.5.3-1, and a very basic ant build file that works fine from the command
line.
Ant Home is set: C:\Java\apache-ant-1.5.3-1
Ant Runtime classpath is configured as:
C:\Java\j2sdk1.4.2\lib\dt.jar
C:\Java\j2sdk1.4.2\lib\htmlconverter.jar
C:\Java\j2sdk1.4.2\lib\tools.jar
C:\Java\apache-ant-1.5.3-1\lib\ant.jar
C:\Java\apache-ant-1.5.3-1\lib\optional.jar
C:\Java\apache-ant-1.5.3-1\lib\xml-apis.jar
I removed xercesImpl.jar since I've read many posts and articles that said
this causes problems.
When I attempt to build I get:
BUILD FAILED: java.lang.VerifyError:
(class:org/apache/xerces/parsers/IntegratedParserConfigurati on, method:
configurePipeline signature: ()V) Incompatible type for getting or setting
field
Total time: 203 milliseconds
I apologize for this repost but I have spent considerable time reading
newsgroups, websites, and articles and can't find out what is wrong.
Any assistance is appreciated. Thanks!
Re: Has anyone gotten Ant to work under Eclipse? [message #74944 is a reply to message #74927] Fri, 11 July 2003 15:27 Go to previous messageGo to next message
No :-)
Just kidding, :-)
I believe there are thousands of people who have had success and I think I
have replied to this with a path to success... but who knows with how the
newsgroup has been working of late.
Remove C:\Java\apache-ant-1.5.3-1\lib\xml-apis.jar as well
As well, because of manifest entries in the ant.jar and the optional.jar you
will need to physically move the xerces jars to a different directory than
the ant and optional.jars.
BTW, why are you not just using the default configuration? Ant comes with
Ant 1.5.3 as a plugin (org.apache.ant) and if you use the default you would
not have all of these problems. We do try to make life easy :-)
Darins
"Roger Wilco" <wilco909@hotmail.com> wrote in message
news:bemvkh$are$1@eclipse.org...
> line.
> field
Re: Has anyone gotten Ant to work under Eclipse? [message #75266 is a reply to message #74944] Sat, 12 July 2003 16:43 Go to previous messageGo to next message
I removed xml-apis.jar and still get the exact same error.
I tried with the default configuration and got some other error. I have
ended up with my current configuration based on reading many posts and
articles. Believe me, if the default configuration worked, I would be very
happy to stick with that.
Is there any way to revert back to the default? Is there a preferences file
to delete or maybe a complete reinstall of Ant?
Thanks for the reply!
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:ben315$ekv$1@eclipse.org...
> No :-)
> Just kidding, :-)
I
you
would
> Darins
command
> > line.
setting
> > field
Re: Has anyone gotten Ant to work under Eclipse? [message #75300 is a reply to message #75266] Sat, 12 July 2003 18:55 Go to previous messageGo to next message
Did you move the Xerces JARs from the physical location?
What other error did you get with the default configuration?
To restore the default settings, hit restore defaults on the relevant
preferences pages.
HTH
Darins
news:bepkpe$b83$1@eclipse.org...
file
> > No :-)
> > Just kidding, :-)
think
> I
the
> you
than
with
> would
> > Darins
> command
> > > line.
method:
> setting
> > > field
Re: Has anyone gotten Ant to work under Eclipse? [message #76099 is a reply to message #75300] Tue, 15 July 2003 14:20 Go to previous messageGo to next message
I didn't move any JARs from their physical locations.
I did I Restore Defaults and I get:
compile:
[javac] Compiling 7 source files to C:\Program
Files\eclipse\workspace\DNS Simulator\build
[javac] BUILD FAILED: file:C:/Program Files/eclipse/workspace/DNS
Simulator/build.xml:18: Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK
Total time: 578 milliseconds
Manually setting JAVA_HOME from the command prompt before running Eclipse
doesn't change anything.
Thanks for your help!
news:beq3fb$ks5$1@eclipse.org...
> preferences pages.
> HTH
> Darins
Re: Has anyone gotten Ant to work under Eclipse? [message #76114 is a reply to message #76099] Tue, 15 July 2003 12:22 Go to previous messageGo to next message
The other most frequently asked Ant questions :-)
The JAVA_HOME error message is from Apache Ant which does not "know" that it
has been integrated within Eclipse.
You need to have a jdk tools.jar on the Ant runtime classpath using the
Ant preference pages.
This is done for you automatically if you start Eclipse using a JVM from a
JDK install (as opposed to a JRE install). This is accomplished using
the -vm arg.
Alternately, you can set the build.compiler property to
"org.eclipse.jdt.core.JDTCompilerAdapter" if you wish to use Eclipse's
internal compiler for your build
HTH
Darins
news:bf19ga$1pn$1@eclipse.org...
> compile:
> > preferences pages.
> > HTH
> > Darins
Re: Has anyone gotten Ant to work under Eclipse? [message #76445 is a reply to message #76114] Tue, 15 July 2003 21:06 Go to previous message
Wow, that actually works!!!
I swear I checked all the FAQs and did all the searches.
Thank you very much for your help!
news:bf19m5$203$1@eclipse.org...
it
> the -vm arg.
> HTH
> Darins
> > compile:
Eclipse
> > > preferences pages.
> > > HTH
> > > Darins
Re: Has anyone gotten Ant to work under Eclipse? [message #76458 is a reply to message #76445] Tue, 15 July 2003 19:27 Go to previous message
Don't sound sooo surprised :-)
I logged https://bugs.eclipse.org/bugs/show_bug.cgi?id=40165 so we can get
away from this problem.
Glad it worked out,
Darins
news:bf2191$q74$1@eclipse.org...
that
> it
a
> > the -vm arg.
> > HTH
> > Darins
> > > compile:
> Eclipse
relevant
> > > > preferences pages.
> > > > HTH
> > > > Darins
Previous Topic:Odd crash in JDT when merely saving
Next Topic:About using eclipse in difference machine
Current Time: Tue Jul 22 01:36:16 EDT 2025
Powered by FUDForum. Page generated in 0.30610 seconds
