Home » Archived » BIRT » Anonymous CVS access from Eclipse
Anonymous CVS access from Eclipse [message #600] Wed, 29 December 2004 15:36 Go to next message
Originally posted by: kevin.struckhoff.newroads.com
I'm interested in using BIRT for my company's BI strategy. However, I'm
having trouble getting Eclipse to get the CVS source. It always wants a
password for the anonymous user. I'm using the Checkout from CVS window in
Eclipse.
I am using these settings:
Host: dev.eclipse.org
Repository path: :pserver:anonymous@dev.eclipse.org:/home/eclipse/birt
User: anonymous (it won't let me proceed w/o a user)
Connection type: pserver
Use Default port is selected
I'm getting an error sayinng no such repository path. I have also tried
/home/birt.
Please advise.
Thanks.
Kevin Struckhoff
Customer Analytics Mgr
NewRoads West Inc.
Re: Anonymous CVS access from Eclipse [message #612 is a reply to message #600] Thu, 30 December 2004 07:28 Go to previous messageGo to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
The correct location is /home/birt. Can you access any other repository
locations anonymously, such as /home/eclipse? What version of
Eclipse/cvs are you using?
With Eclipse release 3.0.1, I was able to access the repository location
anonymously through pserver.
Denis
> in Eclipse.
> /home/birt.
> Please advise.
> Thanks.
> Kevin Struckhoff
> NewRoads West Inc.
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the FAQ at http://www.eclipse.org/webmaster/faq.html
View my status at http://www.eclipse.org/webmaster/main.html
Re: Anonymous CVS access from Eclipse [message #624 is a reply to message #600] Thu, 30 December 2004 14:19 Go to previous messageGo to next message
Kevin,
Seems to be working today. I tried it last evening when I first saw your
message, and I also could not get it to work. I verified with the Eclipse
webmaster that the settings were right.
In any event, it works now, so give it another try.
- Paul
Paul Rogers
Actuate
Eclipse BIRT PMC
"Kevin Struckhoff" <kevin.struckhoff@newroads.com> wrote in message
news:cqv4gu$ko2$1@www.eclipse.org...
> Eclipse.
> /home/birt.
> Please advise.
> Thanks.
> Kevin Struckhoff
> NewRoads West Inc.
Re: Anonymous CVS access from Eclipse [message #1522 is a reply to message #624] Sun, 02 January 2005 06:17 Go to previous messageGo to next message
Originally posted by: red1.red1.org
The repository path is definitely /home/birt. It does work, as i got it all
down into my Eclipse IDE.
However it complained of not finding a commons-codec-1.3.jar, so i searched
online for one and path to it, that's ok.
But now its having lots of assert stmt errors.
Any1?
regards
red1
Re: Anonymous CVS access from Eclipse [message #1549 is a reply to message #1522] Mon, 03 January 2005 11:32 Go to previous messageGo to next message
.... SNIP...
> Any1?
assert is a java feature as of java 1.4. Look e.g. at
http://java.sun.com/developer/JDCTechTips/2002/tt0409.html
Sven Boden
Re: Anonymous CVS access from Eclipse [message #2807 is a reply to message #1522] Tue, 11 January 2005 12:07 Go to previous message
Sven is right this is a Java 1.4 feature. If you have Eclipse set up to
work with 1.3 Java, you need to change a few things.
Windows >> Preferences >> Java >> Installed JREs make sure you are using
a 1.4 JRE
Windows >> Preferences >> Java >> Compiler >> select tab Compliance and
Classfiles
Set Compiler compliance level to 1.4
Turn off Use default compliance settings
Set Generated .class files compatibility to 1.4
Set Source compatibility to 1.4
Probably makes sense to leave the Disallow identifiers called 'assert' set
to error.
The issue is that by default Eclipse is set up to treat assert as an
identifer (1.3 behavior). The BIRT developers have used assert as a keyword
(1.4 JDK).
Scott Rosenbaum
"red1" <red1@red1.org> wrote in message news:cr8l77$a32$1@www.eclipse.org...
all
searched
> Any1?
> regards
> red1
Previous Topic:ERE Report Consumption
Next Topic:when will chart engine's source code be released?
Current Time: Sat Jul 26 10:34:44 EDT 2025
Powered by FUDForum. Page generated in 0.18936 seconds
