Home » Archived » Voicetools » Questions about status of current builds
Questions about status of current builds [message #6728] Wed, 03 August 2005 10:02 Go to next message
Originally posted by: smillie_family.compuserve.com
Does the current build, vtp-M20050519, work with the WTP Release 0.7 ?
Do you have plans to do a new build using the WTP Release 0.7 ?
There are two sub-projects to the Web Tools Project:
1) Web Standard Tools (WST) Sub-project
2) J2EE Standard Tools (JST) Sub-project
I assume that VTP only requires the Web Standard Tools component. Is this
correct ?
Peter Smillie
Re: Questions about status of current builds [message #6733 is a reply to message #6728] Wed, 03 August 2005 17:45 Go to previous messageGo to next message
Hi -
I just tried putting vtp-M20050519 together with WTP 0.7 this morning.
Unless I made some kind of mistake in installing, it did not work. The
Voice option was not available for creating or opening files.
That version of vtp does indeed work with WTP 0.4, which is still
available for download.
As for your second question, just get the all in one WTP download, and
you will be fine.
-- Mike Greenawalt
Tellme
Smillie Family wrote:
> Hello,
> correct ?
> Regards
> Peter Smillie
Re: Questions about status of current builds [message #6739 is a reply to message #6728] Fri, 05 August 2005 03:03 Go to previous messageGo to next message
Originally posted by: lists.remove-me.varnes.remove-me.net
Hi Peter,
> Hello,
No, it is explicitly built against the drivers listed on the
download page (all prior to the WTP 0.7 release).
The code in CVS has already been updated for Eclipse 3.1 and WTP
0.7. You can build the feature and plugins if you want them, I
do not know what the project plans for the next release are.
> correct ?
I have always assumed this, but have never got around to testing
that it is so ... might do that this weekend :-)
hth
davidv
> Regards
> Peter Smillie
Re: Questions about status of current builds [message #6746 is a reply to message #6728] Mon, 08 August 2005 00:25 Go to previous message
No, that snapshot used WTP M4 I believe. CVS code works fine against 0.7.
Yes, and in fact that should be available in a day or two. I'll send you a
note to let you know when it's available.
> correct ?
I believe this to be the case, yes.
Re: Questions about status of current builds [message #572054 is a reply to message #6728] Wed, 03 August 2005 17:45 Go to previous message
Hi -
you will be fine.
-- Mike Greenawalt
Tellme
> Hello,
> correct ?
> Regards
> Peter Smillie
Re: Questions about status of current builds [message #572086 is a reply to message #6728] Fri, 05 August 2005 03:03 Go to previous message
Hi Peter,
> Hello,
> correct ?
hth
davidv
> Regards
> Peter Smillie
Re: Questions about status of current builds [message #572114 is a reply to message #6728] Mon, 08 August 2005 00:25 Go to previous message
> correct ?
Previous Topic:Voice Tools Development Call Minutes: July 28, 2005
Next Topic:Question about install VTP plugin
Current Time: Thu Jul 17 19:42:28 EDT 2025
Powered by FUDForum. Page generated in 0.03891 seconds
