Home » Archived » Visual Editor (VE) » NullPointerException if I create a VisualClass
NullPointerException if I create a VisualClass [message #74804] Tue, 14 December 2004 05:47 Go to next message
If I create a VisualClass I always receive a NullPointerException.
in the .log is:
eclipse.buildId=I200409240800
java.version=1.4.2_05
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
!ENTRY org.eclipse.osgi Dez 08, 2004 12:51:45.329
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:2717)
at org.eclipse.swt.SWT.error(SWT.java:2616)
at org.eclipse.swt.SWT.error(SWT.java:2587)
at org.eclipse.swt.widgets.Display.createDisplay(Display.java:7 16)
at org.eclipse.swt.widgets.Display.create(Display.java:701)
at org.eclipse.swt.graphics.Device.<init>(Device.java:113)
at org.eclipse.swt.widgets.Display.<init>(Display.java:409)
at org.eclipse.swt.widgets.Display.<init>(Display.java:405)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:295)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:156)
at org.eclipse.ui.internal.ide.IDEApplication.createDisplay(IDE Application.java:127)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:78)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Any help available (e.g. Plattform parameters for handles....)?
Greetings
Andreas
Re: NullPointerException if I create a VisualClass [message #74821 is a reply to message #74804] Tue, 14 December 2004 05:49 Go to previous messageGo to next message
Note:
I have deinstall the gtk_qt binding from Suse 9.2.
The binding doesn't work on Suse 9.2 and Eclipse 3.1
greetings
Andreas
Re: NullPointerException if I create a VisualClass [message #74851 is a reply to message #74804] Tue, 14 December 2004 10:18 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
There has got to be more errors in the .log because this trace has
nothing to do with the VE. It is confusing because this trace indicates
it never even got to the point of bringing up an Eclipse workspace, let
alone start VE.
I also don't know what you mean by deinstalling gtk bindings. VE needs
to have gtk available. Does that mean it is not available?
Also on SUSE, there is a problem in the etc/.hosts file, it has
localhost defined twice, and this screws things up. Go to your
etc/.hosts file and make sure localhost is defined only on the 127.0.0.1
line, and is removed from the :::0 line.
FreeGroup wrote:
> in the .log is:
> !STACK 1
> at
Rich Kulp
Re: NullPointerException if I create a VisualClass [message #74883 is a reply to message #74851] Tue, 14 December 2004 10:21 Go to previous messageGo to next message
Or is it hosts/.etc (? I forget which is it called).
Rich Kulp
Re: NullPointerException if I create a VisualClass [message #75027 is a reply to message #74851] Tue, 14 December 2004 14:52 Go to previous messageGo to next message
> alone start VE.
I'm have clean up my workspace (I create a runtime-workspace for plugin
development) and in this workspace it runs fine.
I can address the wrong setting in my workspace (and I don't want delete them)
There is no more in the .log file!
Any help?
I have deinstalle the gtk-qt-engine which maps the gui from gnome gtk to the KDE
settings/font/gui elements....a gui bridge - I think.
see: https://bugs.eclipse.org/bugs/show_bug.cgi?id=77928
Thanks for the hint...I think I can comment out the line
Greetings
Andreas
Re: NullPointerException if I create a VisualClass [message #75038 is a reply to message #75027] Tue, 14 December 2004 14:54 Go to previous messageGo to next message
tsts... I CAN'T address......
the correct .log [message #75050 is a reply to message #75027] Tue, 14 December 2004 15:18 Go to previous messageGo to next message
Annotation: If I create a runtime-workspace the VE works fine....
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.185
!MESSAGE
!STACK 0
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
java.lang.NoClassDefFoundError: org/eclipse/swt/internal/gtk/GdkEventMotion
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:141)
at org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:143)
at org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n(ConnectionThread.java:47)
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createThrowableBeanProxy(REMThrowableBeanTypeProxy.java: 34)
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanProxy(REMThrowableBeanTypeProxy.java:65)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBeanProxy(REMStandardBeanProxyFactory.java:454)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.processErrorReturn(REMStandardBeanProxyFactory.java:50 5)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getClassReturn(REMStandardBeanTypeProxyFactory.jav a:313)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.createBeanTypeProxy(REMStandardBeanTypeProxyFactor y.java:173)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:290)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:237)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.primInsta ntiateBeanProxy(BeanProxyAdapter.java:857)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teBeanProxy(BeanProxyAdapter.java:755)
org.eclipse.ve.internal.swt.FreeFormControlHostAdapter.add(F reeFormControlHostAdapter.java:77)
at org.eclipse.ve.internal.swt.ControlProxyAdapter.setTarget(Co ntrolProxyAdapter.java:330)
org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList.didAdd(BasicNotifierImpl.java:71)
at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList. java:619)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:5 99)
org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapte rList.add(BasicNotifierImpl.java:115)
org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.associ ate(AdapterFactoryImpl.java:161)
org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.adaptN ew(AdapterFactoryImpl.java:113)
at org.eclipse.emf.ecore.util.EcoreUtil.getRegisteredAdapter(Ec oreUtil.java:100)
org.eclipse.ve.internal.java.core.BeanProxyUtilities.getBean ProxyHost(BeanProxyUtilities.java:353)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itSetting(CompositionProxyAdapter.java:156)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itBeanProxy(CompositionProxyAdapter.java:119)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1488)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.483
!MESSAGE
+++ Warning +++: Tue Dec 14 21:15:49 CET 2004 Project (de.tif.jacob.designer)-VM for
de.tif.jacob.designer:err>java.lang.NoClassDefFoundError: org/eclipse/swt/internal/gtk/OS
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.484
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.486
!MESSAGE
de.tif.jacob.designer:err> at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 63)
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.487
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.488
!MESSAGE
de.tif.jacob.designer:err> at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 54)
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.489
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.490
!MESSAGE
de.tif.jacob.designer:err> at org.eclipse.swt.widgets.Display.<clinit>(Display.java:118)
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.491
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.492
!MESSAGE
org.eclipse.ve.internal.swt.targetvm.Environment$1.run(Envir onment.java:32)
!ENTRY org.eclipse.jem.proxy 2 0 Dez 14, 2004 21:15:49.493
!MESSAGE
!ENTRY org.eclipse.ve.java.core 4 0 Dez 14, 2004 21:15:49.495
!MESSAGE Exception thrown.
!STACK 0
at org.eclipse.jem.internal.proxy.swt.DisplayManager.syncExec(D isplayManager.java:453)
org.eclipse.jem.internal.proxy.swt.JavaStandardSWTBeanConsta nts.invokeSyncExec(JavaStandardSWTBeanConstants.java:135)
at org.eclipse.ve.internal.swt.WidgetProxyAdapter.invokeSyncExe c(WidgetProxyAdapter.java:65)
org.eclipse.ve.internal.swt.ControlProxyAdapter.basicInitial izationStringAllocation(ControlProxyAdapter.java:70)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.primInsta ntiateBeanProxy(BeanProxyAdapter.java:861)
Re: the correct .log [message #75064 is a reply to message #75050] Tue, 14 December 2004 17:10 Go to previous messageGo to next message
For some reason you are missing the GdkEventMotion, whatever that is.
There is something wrong with your installation. Since it works when you
start from runtime-workspace that means there is something different
between the two eclipse installations, or settings on them. Are you sure
you have Eclipse SWT for GTK installed correctly. It appears to be
missing the Eclipse GTK SWT fragments, or at least the code from them.
> !MESSAGE
> !STACK 0
Rich Kulp
Re: the correct .log [message #75274 is a reply to message #75064] Fri, 17 December 2004 13:18 Go to previous message
....after 3 days I dosen't continue with the VE.
I will layout my 2-3 Dialogs direkt with the API. :-(
It is not possible to run the VE in my Eclipse
greetings
Andreas
Re: NullPointerException if I create a VisualClass [message #603881 is a reply to message #74804] Tue, 14 December 2004 05:49 Go to previous message
Note:
greetings
Andreas
Re: NullPointerException if I create a VisualClass [message #603887 is a reply to message #74804] Tue, 14 December 2004 10:18 Go to previous message
alone start VE.
FreeGroup wrote:
> in the .log is:
> !STACK 1
> at
Rich Kulp
Re: NullPointerException if I create a VisualClass [message #603896 is a reply to message #74851] Tue, 14 December 2004 10:21 Go to previous message
Rich Kulp
Re: NullPointerException if I create a VisualClass [message #603908 is a reply to message #74851] Tue, 14 December 2004 14:52 Go to previous message
> alone start VE.
Any help?
Greetings
Andreas
Re: NullPointerException if I create a VisualClass [message #603911 is a reply to message #75027] Tue, 14 December 2004 14:54 Go to previous message
the correct .log [message #603912 is a reply to message #75027] Tue, 14 December 2004 15:18 Go to previous message
!MESSAGE
!STACK 0
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!STACK 0
Re: the correct .log [message #603917 is a reply to message #75050] Tue, 14 December 2004 17:10 Go to previous message
> !MESSAGE
> !STACK 0
Rich Kulp
Re: the correct .log [message #603962 is a reply to message #75064] Fri, 17 December 2004 13:18 Go to previous message
greetings
Andreas
Previous Topic:FYI: VE developers out for the holidays
Next Topic:FYI: VE developers out for the holidays
Current Time: Tue Jul 08 17:59:17 EDT 2025
Powered by FUDForum. Page generated in 0.08844 seconds
