Home » Archived » Visual Editor (VE) » VisualEditor very slow, etc.
VisualEditor very slow, etc. [message #74769] Tue, 14 December 2004 04:01 Go to next message
Originally posted by: mik.c-l-a-s-s-x.it
We're working with the VisualEditor since a month after migrating all our
soruce code base from VisualAge for Java. We develop Swing based desktop
applications so the visual gui building is an important phase of our
development cycle.
I find the VisualEditor very slow even on a high-end machines and I think
the main problem of VE is the slowness of the gui rebuilding, which is a
real pain, even when working with a limited number of components.
Also the gui rebuilding itself is done very frequently due to property
changes (visual) or source code changes.
Some ideas:
1 - why don't you separate the source code update from the gui editing ? We
could, for example, build and modify a gui at full speed and ask for a code
regeneration at the end of the gui editing. User code would be kept intact
in case of further gui editing.
2 - Leave things unchanged but speedup the gui rebuilding as much as you can
by avoiding the source code parsing phase (making use of metadata i.e. for
the classes directly generated inside VE).
3 - Leave things unchanged but speedup the gui rebuilding as much as you can
by pre-parsing the source code (making use of metadata) and then displaying
the gui (this avoids a huge lot of unneded repaints).
Mik
p.s.
there's a little annoying bug in the VE: changing a property of a component
unselects it.
> ClassX Development Italy Via Francesca, 368/I I-56030 S.M. a Monte (PI) <
> Tel.(+39)-0587-705153 Fax.(+39)-0587-705153 WEB: http://www.classx.it <
Re: VisualEditor very slow, etc. [message #74786 is a reply to message #74769] Tue, 14 December 2004 05:26 Go to previous messageGo to next message
Originally posted by: lmorley.wpi.edu
One temporary solution you may or may not have already noticed: when
editing the sourcecode by hand, you can pause GUI repainting ('pause'
button on the toolbar) until you're ready to see it again. (I think this
was more noticeable in 2.x.) This allows you to handwrite sourcecode
without being burdened by constant repainting, but doesn't allow you to
see your changes or make changes through the VE itself.
> development cycle.
> Some ideas:
> Mik
> p.s.
> unselects it.
Liam Morley
Computer Science Undergraduate
Worcester Polytechnic Institute
Re: VisualEditor very slow, etc. [message #75016 is a reply to message #74786] Tue, 14 December 2004 12:01 Go to previous messageGo to next message
Well said, it's just a temporary solution.
I would like to hear the position of the VEP developers.
Mik
"Liam Morley" <lmorley@wpi.edu> ha scritto nel messaggio
news:cpmf4d$of1$1@www.eclipse.org...
Re: VisualEditor very slow, etc. [message #75023 is a reply to message #75016] Tue, 14 December 2004 12:21 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
WE are working on performance. That is the number one thing for the next
release.
Rich Kulp
Re: VisualEditor very slow, etc. [message #75077 is a reply to message #75023] Wed, 15 December 2004 03:12 Go to previous messageGo to next message
Which direction are you taking in order to speedup VE ?
Mik
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> ha scritto nel messaggio
news:cpn7ev$ars$1@www.eclipse.org...
> release.
> Rich Kulp
Re: VisualEditor very slow, etc. [message #75128 is a reply to message #75077] Wed, 15 December 2004 12:54 Go to previous message
Many directions. We are profiling it and seeing what is causing it to be
slow. We will do some pre-building of some caches so that we don't need
to do that every time, and other things. If you are interested in
following some of the things we are doing, look at bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=61944
Rich Kulp
Re: VisualEditor very slow, etc. [message #603877 is a reply to message #74769] Tue, 14 December 2004 05:26 Go to previous message
> development cycle.
> Some ideas:
> Mik
> p.s.
> unselects it.
Liam Morley
Re: VisualEditor very slow, etc. [message #603902 is a reply to message #74786] Tue, 14 December 2004 12:01 Go to previous message
Mik
Re: VisualEditor very slow, etc. [message #603906 is a reply to message #75016] Tue, 14 December 2004 12:21 Go to previous message
release.
Rich Kulp
Re: VisualEditor very slow, etc. [message #603920 is a reply to message #75023] Wed, 15 December 2004 03:12 Go to previous message
Mik
> release.
> Rich Kulp
Re: VisualEditor very slow, etc. [message #603929 is a reply to message #75077] Wed, 15 December 2004 12:54 Go to previous message
Rich Kulp
Previous Topic:How to install the Visual Editor
Next Topic:How to install the Visual Editor
Current Time: Fri Nov 07 00:01:05 EST 2025
Powered by FUDForum. Page generated in 0.04698 seconds
