Home » Archived » XML Schema Definition (XSD) » XSD Ecore File Open Source ?
XSD Ecore File Open Source ? [message #74688] Mon, 16 June 2008 09:21 Go to next message
I was looking for the *.ecore file which was used to create the XSD-editor.
Since XSD is EMF based I guessed there must be an ecore-model which the
editor is build on.
Is it available for anybody, and when this is the case, where can I find
it ?
On the other side, is my guess wrong and there is no such file ?
I'm part of a project team at the technical university of berlin and we are
are developing our own modeling tools (among other things a XML editor)
based
on GMF. Since XSD fits nearly our requirements, we are very interested in
the
ecore metamodell file.
Thanks in advance,
Tim Broemme
Re: XSD Ecore File Open Source ? [message #74706 is a reply to message #74688] Mon, 16 June 2008 09:30 Go to previous messageGo to next message
Tim,
Comments below.
Tim Broemme wrote:
> XSD-editor.
It's org.eclipse.xsd/model/XSD.ecore.
> the editor is build on.
Yes, though unfortunately xsd.edit and xsd.editor were generated before
EMF itself was open sourced in its present form and hence neither is
currently being regenerated. Some time I'll need to work on that...
> find it ?
> we are
> editor) based
> in the
WTP has a very nice graphical XSD editor...
> Thanks in advance,
> Tim Broemme
Re: XSD Ecore File Open Source ? [message #74722 is a reply to message #74706] Mon, 16 June 2008 12:06 Go to previous message
thanks for your very fast reply.
you helped a lot.
Re: XSD Ecore File Open Source ? [message #603085 is a reply to message #74688] Mon, 16 June 2008 09:30 Go to previous message
Tim,
Comments below.
Tim Broemme wrote:
> XSD-editor.
> find it ?
> we are
> editor) based
> in the
> Thanks in advance,
> Tim Broemme
Re: XSD Ecore File Open Source ? [message #603088 is a reply to message #74706] Mon, 16 June 2008 12:06 Go to previous message
you helped a lot.
Previous Topic:XSD Ecore File Open Source ?
Next Topic:XML Schmema Editor GUI - Sourcecode
Current Time: Mon Jul 21 21:12:41 EDT 2025
Powered by FUDForum. Page generated in 0.04375 seconds
