Home » Eclipse Projects » GEF » How to draw vertical text?
How to draw vertical text? [message #74554] Fri, 04 April 2003 06:09 Go to next message
Originally posted by: yuancong.tsinghua.org.cn
Are there methods to draw vertical text?
Re: How to draw vertical text? [message #74576 is a reply to message #74554] Fri, 04 April 2003 07:34 Go to previous message
There is no way to rotate text. You could try drawing normal next to an
Image buffer, and then manually rotating the ImageData.
"YUAN Cong" <yuancong@tsinghua.org.cn> wrote in message
news:b6jos1$sed$1@rogue.oti.com...
Previous Topic:GEF Hello 6 tutorial does not compile
Next Topic:how to surface properties view when selecting edit part
Current Time: Wed Jul 09 09:41:58 EDT 2025
Powered by FUDForum. Page generated in 0.04772 seconds
