Home » Eclipse Projects » Remote Application Platform (RAP) » Param-Types vom java to js and vice versa
Param-Types vom java to js and vice versa [message #74341] Mon, 18 February 2008 06:27 Go to next message
Originally posted by: andy.allgau.org
I just wondered, how are parameter-types encoded between the java and the
js - side? boolean, string etc. is clear, but what happens if i pass an
non-primitive type as argument? how is this encoded?
Bye!
Andy
Re: Param-Types vom java to js and vice versa [message #74468 is a reply to message #74341] Tue, 19 February 2008 02:05 Go to previous message
Originally posted by: fappel.innoopract.com
most of the times RAP uses primitives. There is no automated way of
marshalling object types. If needed this has to be done by the custom
component developer using the LCA and the clientside javascript
representation of the widget.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Andy [mailto:andy@allgau.org]
Bereitgestellt: Montag, 18. Februar 2008 12:27
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Param-Types vom java to js and vice versa
Betreff: Param-Types vom java to js and vice versa
the js - side? boolean, string etc. is clear, but what happens if i pass
an non-primitive type as argument? how is this encoded?
Bye!
Andy
Previous Topic:symbol problem
Next Topic:Alignment of Text
Current Time: Mon Jul 21 21:35:25 EDT 2025
Powered by FUDForum. Page generated in 0.03743 seconds
