Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Missing model element when generating Teneo hibernate mapping
Missing model element when generating Teneo hibernate mapping [message #74312] Thu, 08 March 2007 11:05 Go to next message
Hi ,
Im attempting to generate a hibernate mapping for my EMF model. The
model is generated from a fairly complex Rose model composed of one
main model file and six .cat files. The EMF model is generated without
any problems.
When I attempt to generate a Hibernate mapping through Teneo by
right clicking on any of the six different .ecore files which make up
the parts of the model I always receieve an error in the form:
Exception in thread "main" java.lang.IllegalArgumentException: No
annotated model element present for: Structure for type EClass has its
epackage been registered with Teneo?
org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedMod elImpl.checkAnnotatedPresent(PAnnotatedModelImpl.java:323)
org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedMod elImpl.getPAnnotated(PAnnotatedModelImpl.java:269)
org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.pr ocessClass(DefaultAnnotator.java:276)
org.eclipse.emf.teneo.hibernate.hbannotation.util.HibernateD efaultAnnotator.processClass(HibernateDefaultAnnotator.java: 140)
org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.pr ocessPackage(DefaultAnnotator.java:246)
org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.ma p(DefaultAnnotator.java:159)
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:158)
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:90)
org.eclipse.emf.teneo.hibernate.mapper.GenerateHBM.createORM apperFile(GenerateHBM.java:104)
org.eclipse.emf.teneo.hibernate.mapper.GenerateHBM.main(Gene rateHBM.java:84)
For each of the different .ecore files the annotated model element
referred to in the error is different. I have successfully generated
mappings for very simple models but I'm at a loss as to where to look
for the source of the error in this instance.
Im running Eclipse 3.2, Teneo 0.75, EMF2.2, Hibernate 3.2
Any help greatly appreciated.
Duncan
Re: Missing model element when generating Teneo hibernate mapping [message #74349 is a reply to message #74312] Thu, 08 March 2007 11:20 Go to previous messageGo to next message
Hi Duncan,
The generation needs the complete model (so all ecore files). You should be able to select all ecore
files (so multiple select) and then right-click and generate the mapping.
Note if you initialize a datastore also all the epackages (from all the ecore files) should be set
in the datastore.
gr. Martin
Duncan ALexander wrote:
> Hi ,
> any problems.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Duncan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Missing model element when generating Teneo hibernate mapping [message #74385 is a reply to message #74349] Thu, 08 March 2007 11:45 Go to previous message
Aah,
thats one of those answers which makes you go 'Doh! why didnt I try that' ?
Thanks again, thats it working now.
Duncan
Martin Taal wrote:
> Hi Duncan,
> be able to select all ecore files (so multiple select) and then
> ecore files) should be set in the datastore.
> gr. Martin
>> Hi ,
>> The model is generated from a fairly complex Rose model composed of one
>> any problems.
>> its epackage been registered with Teneo?
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Duncan
Re: Missing model element when generating Teneo hibernate mapping [message #603301 is a reply to message #74312] Thu, 08 March 2007 11:20 Go to previous message
Hi Duncan,
in the datastore.
gr. Martin
> Hi ,
> any problems.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Duncan
The Netherlands
Re: Missing model element when generating Teneo hibernate mapping [message #603308 is a reply to message #74349] Thu, 08 March 2007 11:45 Go to previous message
Aah,
Duncan
Martin Taal wrote:
> Hi Duncan,
> gr. Martin
>> Hi ,
>> any problems.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Duncan
Previous Topic:EMaps and the missing @MapKey annotation
Next Topic:[Teneo] Invalid subclass tag in hibernate mapping file .
Current Time: Tue Jul 22 01:45:42 EDT 2025
Powered by FUDForum. Page generated in 0.26897 seconds
