Home » Language IDEs » C / C++ IDE (CDT) » Integration of existing C / X / Motif code using Eclipse
Integration of existing C / X / Motif code using Eclipse [message #74289] Mon, 30 June 2003 02:00 Go to next message
Originally posted by: raghav.easi.soft.net
We have a CAD application coded in C using X/Motif calls running on
Unix/Linux. The same code runs on Windows using Exceed to convert the
X/Motif calls to native Windows calls. We want to use Eclipse for all out
future development.
1. Is it possible to use Eclipse to build the application to run on both
Unix and Windows without using Exceed and without re-writing the X/Motif
calls in Java?
2. We will be developing new GUI modules using Java in Eclipse. How can we
integrate this new Java GUI modules with existing GUI modules written in C?
Thanks in advance,
Raghav
Re: Integration of existing C / X / Motif code using Eclipse [message #76318 is a reply to message #74289] Fri, 18 July 2003 15:09 Go to previous message
Originally posted by: dschaefe.ca.ibm.com
If you can code it and write the makefile for it, you can use the CDT to
develop it.
Doug
"Raghav" <raghav@easi.soft.net> wrote in message
news:bdojlk$uut$1@rogue.oti.com...
> future development.
> calls in Java?
C?
> Thanks in advance,
> Raghav
Previous Topic:Cross platform CDT...
Next Topic:ctags
Current Time: Fri Jul 11 21:20:40 EDT 2025
Powered by FUDForum. Page generated in 0.03559 seconds
