How to run eclipse on FreeBSD [message #74260] |
Thu, 10 July 2003 13:39  |
Originally posted by: warren.roberts.name
Has anyone been able to run eclipse on FreeBSD? I downloaded the linux
version and tried to run it with the command :
eclipse -vm pathtomyjjvm
It comes up with an error trying to load libgtk-x11-2.0
I have motif and kde installed but not gtk. I thought is was supposed
to run with motif?
Any help would be greatly appreciated.
Thanx
Warren Roberts
Re: How to run eclipse on FreeBSD [message #74350 is a reply to message #74332] |
Thu, 10 July 2003 19:01   |
Originally posted by: muelleimer.usenet.katzien.de
Hallo!
>> to run with motif?
> Try getting the motif version. (they are different files on the download
> page)
Just to let you know: The motif version has also Dependencies on GTK:
jan@snoopy:~$ apt-cache show libswt-motif-java
Package: libswt-motif-java
Version: 2.1.1-1.1
Depends: bonobo-activation (>= 1:2.2.1.1), kdelibs4 (>= 4:3.1.2),
libbonobo-activation4 (>= 1:2.2.1.1), libc6 (>= 2.3.1-1), libglib2.0-0
(>= 2.2.1), libgnomevfs2-0 (>= 2.2.3), liblinc1 (>= 1:1.0.0),
libmotif, liborbit2 (>= 1:2.6.0), libqt3-mt (>= 3:3.1.2), xlibs (>>
4.1.0), java-common
Description: Fast and rich GUI toolkit for Java, motif version
jan@snoopy:~$ ls /usr/lib/eclipse/
eclipse libswt-gnome-motif-2135.so
libswt-motif-2135.so libcore_2_1_0a.so
libswt-gtk-2135.so libswt-pi-gtk-2135.so
libswt-gnome-gtk-2135.so libswt-kde-motif-2135.so
libupdate.so
Until now I haven't figured out, why there are also the gnome and kde
libs... libcore is for providing filaccess support (notice when a file
is changed), libupdate goes to the update plugins... Eclipse 2.1.1...
Jan
Re: How to run eclipse on FreeBSD [message #74368 is a reply to message #74350] |
Thu, 10 July 2003 19:19   |
AFAIK the gnome and kde libs are for interaction with the respective
window managers (they were in 2.0 at least) If you don't happen to have
either the kde or gnome installed that should be ok. We created a
special RPM for them without dependency information as they weren't
required (i.e the motif version should run even if you don't have kde or
gnome installed and if you are using kde or gnome it uses some of the
window manager hints). That may have changed of course. Fuzzy on the the
details been awhile since I looked at it.
It would be a bug if the motif version had a hard dependency on GTK.
Peter
Jan Schulz wrote:
> Hallo!
>>>to run with motif?
>>page)
> Version: 2.1.1-1.1
> 4.1.0), java-common
> libupdate.so
> Jan
Re: How to run eclipse on FreeBSD [message #78587 is a reply to message #78513] |
Sun, 20 July 2003 20:19  |
> WOW!! Thanx for pointing this out to me. This port is new, since I
> started trying to get eclipse to run. I'm updating my ports tree now
> and will build it.
>> There is a port under /usr/local/ports/java/eclipse it should work
>> without
>> any problems.
Here is the complete trace
!ENTRY org.eclipse.ui 4 4 Jul 20, 2003 18:10:33.889
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 Jul 20, 2003 18:10:33.895
!MESSAGE Failed to execute runnable
(java.lang.ArrayIndexOutOfBoundsException: 32)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2332)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:101)
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:1618)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1436)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:468)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
!ENTRY org.eclipse.ui 4 4 Jul 20, 2003 18:10:33.912
!MESSAGE
*** Stack trace of contained exception ***
!ENTRY org.eclipse.ui 4 0 Jul 20, 2003 18:10:33.916
!MESSAGE 32
!STACK 0
at org.eclipse.swt.graphics.ImageData.getPixel(ImageData.java:6 26)
org.eclipse.jface.resource.CompositeImageDescriptor.drawImag e(CompositeImageDescriptor.java:99)
org.eclipse.jdt.ui.JavaElementImageDescriptor.drawCompositeI mage(JavaElementImageDescriptor.java:165)
org.eclipse.jface.resource.CompositeImageDescriptor.getImage Data(CompositeImageDescriptor.java:190)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:118)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:94)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:83)
org.eclipse.jdt.internal.ui.viewsupport.ImageDescriptorRegis try.get(ImageDescriptorRegistry.java:67)
org.eclipse.jdt.ui.ProblemsLabelDecorator.decorateImage(Prob lemsLabelDecorator.java:150)
org.eclipse.jdt.internal.ui.viewsupport.JavaUILabelProvider. getImage(JavaUILabelProvider.java:125)
org.eclipse.jdt.internal.ui.javaeditor.JavaEditorErrorTickUp dater.updateEditorImage(JavaEditorErrorTickUpdater.java:75)
org.eclipse.jdt.internal.ui.javaeditor.JavaEditorErrorTickUp dater.problemsChanged(JavaEditorErrorTickUpdater.java:63)
org.eclipse.jdt.internal.ui.viewsupport.ProblemMarkerManager $1.run(ProblemMarkerManager.java:183)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:98)
!ENTRY org.eclipse.jface 4 2 Jul 20, 2003 18:10:34.183
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
org.eclipse.ui.internal.decorators.DecoratorOverlayIcon.draw CompositeImage(DecoratorOverlayIcon.java:106)
org.eclipse.ui.internal.decorators.OverlayCache.getImageFor( OverlayCache.java:34)
org.eclipse.ui.internal.decorators.OverlayCache.applyDescrip tors(OverlayCache.java:64)
org.eclipse.ui.internal.decorators.DecorationResult.decorate WithOverlays(DecorationResult.java:48)
org.eclipse.ui.internal.decorators.DecorationScheduler.decor ateWithOverlays(DecorationScheduler.java:146)
org.eclipse.ui.internal.decorators.DecoratorManager.decorate Image(DecoratorManager.java:209)
org.eclipse.jface.viewers.DecoratingLabelProvider.getImage(D ecoratingLabelProvider.java:75)
org.eclipse.jface.viewers.TreeViewer.doUpdateItem(TreeViewer .java:96)
org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:87)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1006)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:406)
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:119)
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:1271)
org.eclipse.jface.viewers.StructuredViewer.update(Structured Viewer.java:1253)
org.eclipse.jface.viewers.StructuredViewer.update(Structured Viewer.java:1187)
org.eclipse.jface.viewers.StructuredViewer.handleLabelProvid erChanged(StructuredViewer.java:638)
org.eclipse.jface.viewers.ContentViewer$1.labelProviderChang ed(ContentViewer.java:74)
org.eclipse.ui.internal.decorators.DecoratorManager$1.run(De coratorManager.java:148)
org.eclipse.ui.internal.decorators.DecoratorManager.fireList eners(DecoratorManager.java:146)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.run (DecorationScheduler.java:172)
FUDForum. Page generated in 0.27991 seconds
