Home » Modeling » M2T (model-to-text transformation) » src directory where code is generated does not appear
src directory where code is generated does not appear [message #6686] Mon, 26 March 2007 23:34 Go to next message
Originally posted by: evaandoli.dodo.com.au
I have a small JET project and the generated Java code goes into a src/
directory which I created.
The directory appears on the file system but NOT showing in the Jet
Project - can anyone let me know how to get this soruce directory visible or
is my JET project setup incorrect?
Stu
Re: src directory where code is generated does not appear [message #6692 is a reply to message #6686] Tue, 27 March 2007 08:02 Go to previous message
Stu:
There is a Package Explorer filter that hides the src folder in JET projects
be default. Do the following:
1) Click the little white triangle in top right-hand corner of the Package
Explorer
2) Click Filters...
3) Check Java Elements from JET Transformation Projects
4) Click OK
Your src folder will reappear.
"Stu" <evaandoli@dodo.com.au> wrote in message
news:eua3bh$bq2$1@utils.eclipse.org...
> or is my JET project setup incorrect?
> Stu
Previous Topic:Re: JET2 - declaring custom tags
Next Topic:concatenation in JET2 in get default function
Current Time: Tue Jul 08 12:16:36 EDT 2025
Powered by FUDForum. Page generated in 0.09071 seconds
