Re: Integrated UML designer/code generator for Eclipse? [message #74503 is a reply to message #74073] |
Mon, 06 June 2005 12:20  |
Originally posted by: eclipse.rizzoweb.com
E.T. Grey wrote:
> Is there an integrated UML designer/code generator for Eclipse (v 3.x
> and above)?. Links to this plug in will be much appreciated.
There's a couple of cheap (or free?) plugins that do UML - search for
the UML category at http://www.eclipse-plugins.info.
If you want big-time tools you can consider the Rational Application
Developer suite from IBM. And Borland also has a Together version that
is Eclipse-compatible. These tools are not cheap, but are considered
"enterprise-class" toolkits (whatever that means).
HTH,
Eric
FUDForum. Page generated in 0.07979 seconds
