Home » Eclipse Projects » Technology Project and PMC » How to set up the debugging configuration in Eclipse?
How to set up the debugging configuration in Eclipse? [message #73919] Tue, 05 December 2006 12:17 Go to next message
Originally posted by: yan818.yahoo.com
Trying to debug an application in Eclipse. If I run the application
from command line, it would be run as:
c:/j2sdk1.4.2/bin/java -Xms128m -Xmx256m -classpath %CLASSPATH%
-Djava.rmi.server.codebase=file:/%MYCLASSPATH%
-Djava.security.policy=%MYCLASSPATH%\server.policy
com.bas.server.HubServer --host localhost:1500 start &
How should I configurate the eclipse debugger in this case? Thanks!
Annie
Re: How to set up the debugging configuration in Eclipse? [message #73938 is a reply to message #73919] Tue, 05 December 2006 14:24 Go to previous message
Best to ask questions like this in the eclipse.newcomer newsgroup.
AnnieG wrote:
> Hi, Trying to debug an application in Eclipse.
Re: How to set up the debugging configuration in Eclipse? [message #601263 is a reply to message #73919] Tue, 05 December 2006 14:24 Go to previous message
Previous Topic:How to set up the debugging configuration in Eclipse?
Next Topic:how to get the eclipse icons
Current Time: Sat Jul 26 02:29:57 EDT 2025
Powered by FUDForum. Page generated in 0.04055 seconds
