Home » Modeling » GMF (Graphical Modeling Framework) » Tutorial4, RCP gmfgen creation fails
Tutorial4, RCP gmfgen creation fails [message #73904] Fri, 03 November 2006 06:02
Originally posted by: andras.balogh.cas.de
I was following the steps made in Tutorial part 4 and things went fine till
generating the gmfgen file. The error is as follows
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri
'http://www.eclipse.org/gmf/2005/mappings/2.0' not found.
(platform:/resource/MyMindmap/model/mindmap.gmfmap, 7, 68)
and there is an "Unhandled event loop exception" afterwards. (And the gmfgen
file is not created...)
The author says to use
2.0 development stream codebase
and
experimental SDK
I downloaded them (or at least I think so: GMF-sdk-2.0M2.zip
GMF-sdk-experimental-2.0M2.zip) but I still have the error. If I correct the
namespace omitting "/2.0" it misses the 'FeatureLabelMapping' class.
What did I do incorrectly, what should I inspect?
thanks,
Andras
Previous Topic:Saving imported EClass types from GMF editor
Next Topic:Can GMF handle derived types?
Current Time: Mon Sep 01 02:34:18 EDT 2025
Powered by FUDForum. Page generated in 0.03576 seconds
