Home » Archived » M2M (model-to-model transformation) » Cannot Find model UML
Cannot Find model UML [message #73896] Wed, 30 January 2008 07:10 Go to next message
Originally posted by: zappasan.gmail.com
Hi.
I'm trying to write a transformation from a UML model to a UML model.
This is the simple rule that I've written:
module UML2UML; -- Module Template
create OUT : UML2 from IN : UML2;
rule ModeltoModel{
from
i: UML!Model
to
o: UML!Model(
name <- i.name
In the Run configuration I've setted UML2 like "Is Metamodel" and the
Model Handler is UML2. When I run the transformation I get in the ATL
console a message "Cannot Find model UML". I've tried to chenge the model
Handler from UML2 to EMF but nothing.
Where is the mistake?
Thank you
Emanuele
Re: Cannot Find model UML [message #73914 is a reply to message #73896] Wed, 30 January 2008 07:55 Go to previous message
Hi!
I've fixed the error. The problem was inside the code: I've wrote
UM2!Model instead of UML2!Model
Thank you anyway
Emanuele
Previous Topic:[ATL] Text wrapped in tags
Next Topic:[ATL] atl transf. from Java code
Current Time: Sun Jul 27 12:29:26 EDT 2025
Powered by FUDForum. Page generated in 0.03452 seconds
